Question about Frigidaire GLTF2940ES Front Load Washer
How to fix washer if the lights come on after its turned off
When starting wipers came on and stay on no matter of position of control, washer fluid over head dome light won't turn on, rear washer and whiper won't work.
Wipers won't turn off......sometimes! - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > Diesel > 6.7L Power Stroke Diesel
Feb 3, 2014 - Starting around 25,000 miles my wipers stayed on the slowest intermittent setting even when ... They only two that come to mind is the switch inside the cab or the wiper motor control board. ... The wipers do not park at the correctposition ... It doesn't really matter what steps need to be taken to fix the issue.
Window washer fluid put in window washer won't work now.
www.cargurus.com > Questions > Kia > Sorento
CarGurusAug 31, 2015 - Window washer fluid put in window washer won't work now. ... 4 answers. wipers working, not the washer though, pulled pump, intake screen clean. 2011 Kia Sorento Base ... Interior lights do not work when door is opened 7 answers. At first the back seat overhead light stopped working. Kia said it would ...
Nov 26, 2015 | 2011 Dodge Durango RT
I have a wtw5600xw0 Whirlpool washer. When I press the start button the sensing light and lid lock lights turn on. Then after a few seconds the lid lock light goes off and the sensing light stays...
Swich off the machine, try some WD40 on the door mechanism (on machine lock, not on the door) and open & shut for a minute or two. Then try the machine, spin only just to try.
Rate pl, if solved, or dont!
Source
Nov 27, 2012 | Whirlpool WTW5600X Washer
Kenmore Oasis washer model 110.2709 - Clean washer light is on and machine beeps, after we run the clean washer cycle the light and beep does not clear out. I can't get the washer to run a wash cycle...
Ok this is easy there was a defect on all of them don't worry easy and free fix I want you to call this # (800) 659-7026 they will get your info and send someone out to replace control board. Free. In mean time I want you to unplug washer because it's dc motor it still has juice so hit power then stop tell the lights don't come on plug back in and enjoy the temp fix tell they come out to fix it. Don't worry I sell them and I have one and it is still a great washer it was just the first one out of it's kind so it had flaws but sears is taking care of it's customers.
Apr 21, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I changed the x clamps with rubber washers and bolts put new thermal past and fixed the three red lights but now the center light turns green but i am not getting any signal to a monitor or tv.
It is suggested to use nylon washers, not rubber, in combination with steel washers, as well. Try using two nylon washers on each side of the motherboard, and two steel washers on each side of the nylon washers. So that it will look like this:
Steel washer
Nylon washer
Motherboard
Nylon washer
Steel washer
Of course, with the screw through all of those. And if you take the heatsinks off again, you'll have to redo the paste. Did you perhaps put too much paste on? Only a rice grain size is needed on each chip.
Are you using the correct M5 washers? Did you use Arctic Silver 5 thermal paste?
Did you allow the GPU to "bake? After you do the xclamp fix, it is good to position the fans onto just the CPU and let the xbox run so that the GPU overheats, and this "reflows" the solder. Let it do this for about 20 minutes, until the GPU heatsink is extremely hot.
I would recommend doing the above because it seems like you may have fixed it from overheating to the point that it red rings, but the root problem hasn't been fixed, and allowing the GPU to bake usually solves this.
Dec 07, 2009 | Microsoft Xbox 360 Console
Tail Lights & Brake Lights stay on even when car is turn off
the plastic round stopper most probably broke that is were the stoplight switch sits when not depressed easy fix find a washer small enough to block the hole were the original plastic stopper was making sure the washer aligns to the brake light switch and secure washer w/ zipties hope this helps.
Aug 11, 2009 | 1993 Honda Accord
Control lock light is on , washer won't start
your controll is in child lock turnning power off wont fix find the lock button and push hold till light goes out
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag neptune washer
Doesn't your unit have a lock light in addition to an on light? On mine when you start the machine a red light comes on, then after a minute or two the lock light above it comes on. Once the lock light lights, the machine shouldn't stop. If only the initial light comes on, the door isn't locking. As a result, as the drum moves the clothes and they push against the unlocked door, it turns the machine off. You might need to check/tighten the door latch. Also check the door wax motor/door lock assembly.
Dec 10, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Frigidaire GLTF2940ES Front Load Washer Logo
78 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
