Question about Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System Theater System
I have lost the sound on my HT-BD2R which i bought in December 2008. I called Samsung support, but they could not help me. We tried the test system, but all the speakers are quiet. Do you have an advice what to do? Do you think it could help to upgrade the player with the last software-version? Best regards Rune Bye
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
If your television has RCA style audio/video output you can use an audio RCA cable (red & white connectors) and simply plug from the 'output' of your television into the auxilliary input on the back of the HT-BD2.
Then select AUX on the HT-BD2 remote, whenever you wish to listen to the television audio.
Posted on Mar 30, 2009
Anonymous
SOURCE: NEED TO UPGRADE MY HT-BD2 SYSTEM
There are two ways to approach this. You can either download the update from Samsung's support page, burn it onto a CD, place the CD into your Blu-Ray player and let the update load...or you can connect your Blu-Ray player to the internet and let the player download and install the update automatically.
For the first approach, the upgrade file can be downloaded by clicking on the following link:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=2149020&CDCttType=FM&ModelType=N&ModelName=HT-BD2&VPath=FM/200903/20090318095607437/081227_01_HT_BD2_XAA.zip
...and the instructions to installing the file on your system can be found here:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=2149021&CDCttType=FM&ModelType=C&ModelName=HT-BD2&VPath=FM/200901/20090109105847140/HT-BD2_System_Upgrade_by_CD_Method.pdf
The second approach is detailed in the HT-BD2 User's Manual (pages 46-49). It requires you to first plug a network cable into the back of your Blu-Ray home theater unit, then connect the other end into a LAN connection on your wall (or into the back of your cable/DSL modem) Page 26 of the user's manual shows you how to make the connection.
Posted on Jun 19, 2009
Samsung HT TX500 won't play any dvd, just states that there is no dvd, or keeps attempting to load the disk (makes a loud whirring sound)
If the optical pickup(laser) cannot read the disk, it will in fact say no disk, as it doesn't see one there. For more information, or should you have more questions, please visit my website at audioserviceclinic.com. You may contact me directly through the website. Thank you.
Dec 18, 2013 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
I need a remote instruction book for samsung AH59-02298A
i have a samsung htbd2 lost the remote 4 it.but i have a universal remote 4 my lg tv could i use tthat same remote to run my ht/bd2 aswell? cos i have tried playing it through the ht/bd2 mail unit but keeps coming up with a red circle with a line through it please can you help me?
Jul 02, 2011 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Turning off and writing prot
It's not clear where you're seeing "protect" nor how you're connected to your TV so I have to make some assumptions.
The manual for the HT-BD2R wasn't available but the HT-BD2/HT-BD2S was...
http://www.retrevo.com/support/Samsung-HT-BD2-Home-Theater-Systems-manual/id/22986bh646/t/2/
Read the section of page 24 regarding HDCP and page 70 regarding Copy Protection.
If the unit is powering itself off...
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 15, 2011 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
How can I connect my PS3 to the HT BD2 and get it to play dolby digital or dts audio? Thanks
Use an optical cable and then it should work just fine. Just saw Avatar from my PS3 through the Samsung HT-BD2 and the sound was excellent.
So go and buy an optical cable :)
My problem is to get the BD2 to download updates. It doesn´t seem to work for me.
Apr 12, 2010 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
I have a Samsung HT BD2 region 4, I go many region 1, they wont play, how can I make it play?
To unlock the DVD code its defends upon what region you belongs or from were you bought the DVD unit. Just click this site to hack the region code ; http://www.videohelp.com/dvdhacks
To keep it simple, this means that DVD players and DVDs are labeled for operation on within a specific geographical region in the world. For example, the U.S. is in region 1. This means that all DVD players sold in the U.S. are made to region 1 specifications. As a result, region 1 players can only play region 1 discs. That's right, the DVDs themselves are encoded for a specific region. On the back of each DVD package, you will a find a region number (1 thru 6).
The geographical regions are as follows:
REGION 1 -- USA, Canada
REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
REGION 5 -- Eastern Europe, Russia, India, Africa
REGION 6 -- China
REGION 7 -- Reserved for Unspecified Special Use
REGION 8 -- Reserved for Cruise Ships, Airlines, etc...
REGION 0 or REGION ALL -- Discs are uncoded and can be played Worldwide, however, PAL discs must be played in a PAL-compatible unit and NTSC discs must be played in an NTSC-compatible unit.
The end result is that DVDs encoded for regions other than Region 1 cannot be played on a region 1 DVD player, also, players marketed for other regions cannot play region 1-stamped DVDs
Hope it may help you;
Regards;
VOTIT
Jun 08, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Apr 05, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Blu-Ray disc does not play.
You need a software upgrade. If your blu-ray is lan connected you can upgrade from the blu-ray, just follow the menu. If you have no internet connection, use your PC. On the manufacturers web site find your model and download a firmware update to cd, then play this in your blu-ray, follow the on screen menu. Good luck
Jan 31, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
Nov 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Firmware upgrade
Hi there Michael, here is the link for the new firmware
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=au&CttFileID=2047698&CDCttType=FM&ModelType=N&ModelName=HT-BD2T&VPath=FM/200903/20090318092954656/081227_01_HT_BD2_XSA.zip
Sep 14, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System Theater System Logo
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
