Question about Maytag Neptune Washer
What causes an OE code and the hot water keeps filling the tub on a 2005 Maytag Neptune front load washing machine
6ya staff
SOURCE:
TheRepairGur
Chris Z
  • 27 Answers
SOURCE: 1999 maytag neptune washer stops after filling up with water
There are a couple of common causes for a problem like this. First is a bad door lock assembly that also damages the machine control board (in the control panel). If this is the case the R11 resistor on the machine control board will be burnt.
Maytag has identified seven resistors that relate to specific components that need to be checked or replaced if the resistor is damaged. Listed here are the resistor identification, the circuit involved, and the recommendation:
R9 / pressure switch / check for loose connections or high resistance on switch contacts; replace pressure switch if necessary.
R11 / door lock wax motor / replace door lock mechanism and machine control board.
R51 / hot water valve solenoid / replace water valve and machine control board.
R52 / timer motor / check for loose relay terminal connections and replace machine control board.
R53 / cold water valve solenoid / replace water valve and machine control board.
R143 / (-) 24 Volt DC / contact was made between neutral and the 24 Volt DC circuit.
R162 / electrical buffer circuit / wire harness and machine control board.
Another common issue is a slow water fill fault. If the washer does not fill within a certain time the control will stop on a fault. Usually when this happens the START button can be pushed to continue the cycle.
Washing machines that won't fill or fill slowly often have a restriction in the incoming water supply -- usually in the screens of the inlet hose washers or the water inlet valve itself. Remove the hoses to inspect this condition. If the water inlet valve screens are plugged, replace the water inlet valve.
Go here for: Maytag Neptune Washer Parts
RepairClinic.com
Appliance parts, help & more
Posted on Apr 29, 2009
Anonymous
SOURCE: my maytag front loader will not drain water oe comes on the control panel
On the 9700s it's even easier - three screws on the front bottom panel below the door, then use your hand to unscrew the large round handle in the front center. When you can't unscrew any more, pull gently and the filter / catcher will come out.
It's amazing how much stuff mine held - 4 breastfeeding shields, a pencil, a pen, a fake mouse, and lots of grey gunk.
Screw it back in, put the panel back on, and you're in business.
Posted on May 04, 2009
canbruce75
Bruce Canfield
  • 1776 Answers
SOURCE: MAYTAG NEPTUNE ERROR CODE OE
The "oe" code indicates a water pressure problem. Remove the water supply hoses and check the small metal screens inside the water inlet valve. Make sure they are clear of rust or debris. Check the water inlet valve solenoids. They can can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid I will attach a photo for reference. Hope this helped and best wishes.
Posted on Sep 11, 2009
milten1
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Posted on Oct 10, 2009
wpcustomer
Whirlpool
  • 408 Answers
Creating cleaner, more efficient homes
    Verified Fixya Pro
    SOURCE: My Maytag Neptune front load washer continues to fill with water.
    For troubleshooting assistance please click on the following link
    http://maytag.custhelp.com/app/answers/detail/a_id/2027/kw/continues%20to%20fill/p/293/r_id/108284
    Posted on Jul 17, 2010
    I have a maytag neptune MAH5500BWW. Everytime the water company shuts off the water to repair a leak, the tub fills with water, sometimes overflows onto the floor. Works just fine when there is pressure...
    This is symptomatic of a malfunctioning water control valve- depending on whether it is hot or cold water with which the tub fills.
    Sorry but it needs replacing and a service call ;-0(
    Good luck,
    John C
    Mar 27, 2011 | Maytag Neptune MAH5500B Front Load Washer
    Nf error code
    If there is no water in the wash basket/tub you may have a bad water inlet valve. Try filling with a water mix Hot/Cold will the wash tub will fill and proceed.
    If you need further troubleshooting support post back...........**** or Rich
    Oct 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
    Hi! My neptune tl does not seem to have very hot water. I run the washtub next to it until the water is hot, but if you pause the machine, the water that it is filling with is really cool. Cooler than...
    What happens if you turn of the cold water valve at the supply and do a hot fill....leave the Hot water supply valve open? Do you hear water filling the wash tub or do you error out with a NF error code for no fill?............. D*ick
    Sep 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
    MAYTAG NEPTUNE TOP LOAD DOES NOT FILL TUB WITH WATER HEAR NOISE BUT NO WATER AND STOPS AND 24 MIN QUICK WASH CYCLE, NOT SURE WHERE TO START.
    If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
    Washing Machine Problems No Water
    Washing Machine Fix Washing Machine No Water
    heatman101
    Sep 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
    The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
    If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
    heatman101
    Sep 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
    We just installed the MAH9700AWM Maytag Neptune and got an error code OE? We cancelled cycle, etc still getting issue.
    The "OE" error code means the control detected the water level in the machine is above the overflow level. According to your description the first failure suspect is the water valve possibly stuck. Perform the troubleshooting as described in the tech sheets.
    Here are the break down diagrams for the Maytag Neptune washer Model MAH8700AWW
    Feb 25, 2010 | Maytag MAH9700AWM Neptune Front Load...
    two problems here,
    Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
    MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code "oe",
    if the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
    Mar 02, 2009 | Maytag Neptune MAH9700 Front Load Washer
    Tub fills with water
    replace water valve in the washer. Serial number is needed to find the correct part number. It's likely 22003834, but call any parts supplier with model/serial numbers to verify.
    Good luck,
    Vlad
    First Choice Appliance
    Jan 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Washing Machines Logo
    59 people viewed this question
    Top Maytag Washing Machines Experts
    jimorris77
    Sheldon Dedek
    Bill Long
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
