Question about HP Pavilion a620n (PC028A) PC Desktop
I had the hard drive in my computer replaced and when i put my recovery disc in to reload all the software that came with the computer it is saying "Buffer Overrun Detected" Is this a problem with my recovery disc or is this a problem with my laptop? I dont know whether to call Sony to ask for another recovery disc or call the company that replaced the hard drive? Any suggestions?
  • 585 Answers
If the disk looks to be ok it probably is. If the disk were at fault, I would expect some other error reported. So the problem must lie in the laptop. If you can boot into the Bios, look to see if the new Hard Drive is properly detected, if not, the shop that sold you that bill of goods should have another chance to get it right. You can also try loading the Bios Defaults (remember to "save and exit") and see if that helps. If you take it back, will they load the OS and drivers for you?
Posted on Jun 28, 2009
  • Bruce Volkers
    Bruce Volkers Jun 29, 2009
    mumma 1 brings up a good point. Also, was the harddrive replacement because of failure or an upgrade? Even if it was failed, maybe the shop can read it to copy the backup partition with ghost or a similar application to the new drive for you.
    In the worst case, you're up against buying a new copy of the OS.
    Shy of that, you could perhaps re-install the OS with any installation disk provided that it's a full install of the same version, and that there's a COA sticker on the unit for the key. You may still need to get the drivers from the Sony website
    before it will all work. You can probably do it all yourself, if not or you don't want to mess with it, see what the shop that sold you the drive has to say, maybe they can help you with these suggestions .
  • 903 Answers
All of the information that is needed for the recovery disks to work will be on the old hardrive in a hidden partition. As you have changed the hard drive the recovery disks will not work
6ya staff
SOURCE:
It keeps crashing
Your operating system is in need of repair. Use your recovery disk(s) to perform a repair operation. If that is not available and you cannot get on desktop to perform a system restore, you may just have to reload the drive from scratch.
Sep 10, 2017 | Computers & Internet
Where is the reset button
If you mean how do you return to factory condition, press F11 just before it boots and follow the prompts.
Recovering your computer without recovery discs
Creating recovery discs (or USB storage device solution)
Ordering recovery discs from HP in the United States and Canada
Finding recovery discs from other Web sites
Contacting Support
HP recovery discs can be used to return a computer's software configuration to its original condition. HP provides a recovery solution on the hard drive, but it is still a good idea to keep recovery discs stored in a safe place in the event of a hard drive failure. Use the sections in this document to obtain a recovery solution that works best for you.
NOTE:HP computers designed for commercial use, such as Workstations or Pro series, use "Operating System" or "HP Restore Plus" DVDs. To order these types of discs, go to the HP Replacement Part Store . Recovering your computer without recovery discs You may not need recovery discs to recover the software on your computer. HP provides a recovery solution on a separate area of the hard drive. If the hard drive is still functional, you can still perform an HP system recovery from the hard drive as long as the recovery information has not been destroyed or corrupted.
To do a software recovery from the hard drive, turn on the computer and repeatedly press the F11 key until "Windows is loading files..." displays on the screen. If your computer originally came with Windows XP or earlier, press F10 to enter recovery instead of F11.
  • graphic.php?im=im_e58rok73o1nlhbzFeedback
  • Dec 21, 2013 | HP Pavilion dv6000z Notebook
    Loss my recovery softwear for hp pavilion dm 1
    This is from the HP site:
    HP recovery discs can be used to return a computer's software configuration to its original condition. HP provides a recovery solution on the hard drive, but it is still a good idea to keep recovery discs stored in a safe place in the event of a hard drive failure. Use the sections in this document to obtain a recovery solution that works best for you.note.pngNOTE:HP computers designed for commercial use, such as Workstations or Pro series, use "Operating System" or "HP Restore Plus" DVDs. To order these types of discs, go to the HP Replacement Part Store . Recovering your computer without recovery discsYou may not need recovery discs to recover the software on your computer. HP provides a recovery solution on a separate area of the hard drive. If the hard drive is still functional, you can still perform an HP system recovery from the hard drive as long as the recovery information has not been destroyed or corrupted.To do a software recovery from the hard drive, turn on the computer and repeatedly press the F11 key until "Windows is loading files..." displays on the screen. If your computer originally came with Windows XP or earlier, press F10 to enter recovery instead of F11.
    If you are simply trying to restore the computer to factory install, you may not need the recovery discs.
    If you have suffered a hard drive failure, then there are a couple of options on their website, just ensure you have the exact model number of the computer.
    Feb 12, 2013 | Computers & Internet
    When I turn the power on it starts up but just shuts down ten seconds later and keeps starting up and shutting down over and over again
    This may be a hard drive issue, remove the hard drive and power up the computer it should show the HP logo and go to black screen with a blinking cursor, turn off and re-seat the hardware back in place and restart the laptop, any change? if the same, reload the recovery disc if available this will prove if it's a software issue or hard disc problem. If there is no improvement the hard drive should be pulled and tested at a computer shop before buying a replacement.
    Feb 13, 2011 | HP Computers & Internet
    Need a Acer Aspire m1610 recovery disc
    Go to Acer.com and click on Support; put your model number in (and perhaps, serial number) and you will be able to order a DVD with all the software that was factory installed on your PC. It will cost somewhere over $100.
    Alternatively, you can download Macrium Reflect - Free Version and install it. You must be connected to the Internet when you install to get the free license. Connect an external USB hard drive and Reflect will make you a disk image of all of your installed software as well as all of your word, picture, music and video files. If you have a computer or hard drive failure, you will be able to reload everything onto a new hard drive or computer. You can buy an external USB hard drive for about $85 and everyone should backup their hard drive anyway.
    Oct 13, 2010 | Computers & Internet
    Needs new hard drive. Which hard drives are compatable and can I install a new hard drive and then simply insert the recovery disc to install the original programs and go from there with the upgrades...
    According to HP's specifications, your computer came with a 250GB SATA (serial ATA) hard drive. All drives have standard mounting dimensions, so any SATA drive would be compatible. HP has manuals here that give detailed steps on how to change the drive if you need help. It's a very simple process. Then yes, just put in your recovery disc and reload the original software. You'll then need to reinstall updates, any applications you put on, and so on.
    Hope this gets you running again soon. Thanks for using Fixya!
    Feb 10, 2010 | HP Pavilion a830n (PP166AA#ABA) PC Desktop
    Computer will not allow installation of system software
    yo bro i got a couple things that might help try going to your bios and change the hard drive that it should look to to get the right system running, that is if you have tow different hard drives in the pc. o and also make sure that you have everthing plugged in correctly in your pc. if that doesnt work take out the first hard drive that was installed in the first place and put your new hard drive in its place and put in the right wire also.
    Nov 17, 2009 | Dell Inspiron 6000 Notebook
    Trojan worm on WD1600 XP Home
    it is all done. if u can handle your hard disk separately by
    fixing the hard disk in some other computer, scan with
    BITDEFENDER ANTIVIRUS software. reply for further solution
    Dec 09, 2008 | Western Digital (WD3200JS) 320 GB Hard...
    Toshiba satellite pro l40 boot up problem
    If you run a repair with the recovery disc you won't lose any info. The only time you'll lose the info is if you run a complete reload. Run the system disc until it gets to the point of finding installed operating systems, at this point instead of deleting the partition, press R and it will reinstall the operating system files only leaving other installed files and programs intact. Keep in mind that many times when this happens, it's a hard drive failure. If it is a hard drive failure, then you will have to replace the hard drive and you will lose the info, sorry.
    Jul 02, 2008 | Toshiba Satellite A135-S2276 Notebook
    HP Pavilion a620n (PC028A) PC Desktop Logo
    165 people viewed this question
    Top HP Computers & Internet Experts
    Ekse
    Thomas F. Schneider
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
