How do you turn off power saver for fridaire air conditioner ffre12l301
Good Afternoon Friend,
I understand you want to know how to turn off the power save mode for your Frigidaire air conditioner, model# FFRE12L3Q1. Your appliance will run in energy saver(econ) mode when used for the first time. In this mode, the fan will continue to run for 1 minute after the compressor shuts off. The fan then cycles on for 20 seconds at 10 minute intervals until the room temperature is above the set temperature, at which time the compressor turns back on. You will be able to turn the energy save mode off by selecting your temperature as well as your fan speed. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
SOURCE: Need to know the watts on a Fridaire Air Conditioner 6000 btu
check your name plate voltage and current rating, multiply it and the result is the wattage of the unit.
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
SOURCE: Electronic control on Frigidaire air conditioner not working
which one take live or nuetral ?
common
start
run
thanks
Thank you for your inquiry, Eddie!
From the information you have provided your Frigidaire air conditioner is not turning on after you have plugged it in. I have identified a few possibilities of what could be causing the problem with your air conditioner to be the control panel or power cord. You may be able to perform a reset on your air conditioner by unplugging the power cord and pressing the reset button. You should hear a click and then press the test button. Once you plug it in it should start. If your air conditioner does not start I would suggest contacting the manufacturer for any additional assistance. Hopefully this information is helpful. -Matt
Hi friend, that's a great question!
To reset your Frigidaire air conditioner you would need to make sure the appliance is turned off and unplugged. On the power cord you will see a test button, push that button and you will hear a click. You would then press the reset button you will hear a click again signifying that the appliance has been reset. Then plug your air conditioner back in and it should be reset. -Matt
