SOURCE: Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
SOURCE: GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
SOURCE: GE REFRIGERATOR SPILLS OUT WATER COLLECTED BELOW
Remove the food from the freezer . Remove the rear freezer panel , inside the freezer . At the base in the rear , use a hair dryer and defrost (you'll see a drain hole possibly in the middle of the drain ) . Defrost drain hole until hot water can be poured and go thru the hole . I use a small hose to blow thru the drain hole to remove any debris which could have accumulated inside the drain line .
SOURCE: ice collecting and water overflow from bottom freezer GE
IF YOU TAKE THE BACK OFF THE INSIDE OF THE FREEZER IT IS LOCATED UNDER THE EVAPORATOR COIL IN THE CENTER, IT IS A PIECE OF ALUMINUM SHAPED TO CATCH THE WATER, MELT THE ICE AND BLOW THE HOLE CLEAR
SOURCE: the water is overflowing from the freezer onto refrig shelf
Yes, let the unit thaw out, and replace that thin wire. it's called a drain heater, it simply keeps the water from freezing before it gets out the drain.
