SOURCE: water constantly runing to ice maker/ over flowing ice tray
Flow level has to be clean, or remplace.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/fredis_44a2b9c16ffcde8e
SOURCE: ice maker stopped working. In door water
Hi TBurl,
Yeah... classic sign of a failed water valve. You need a new one. The part number is D7742204 (<---plug that into a search engine or call a local appliance parts outfit to get one).
Easy to replace... Just pull the fridge out, UNPLUG IT FROM THE WALL, turn the water valve off at the wall, remove the water line from the fridge valve, then remove the 2 screws mounting the valve bracket to the base of the fridge. All you have to do now is remove the electrical connectors and the tubing from the old valve and place them on the new one (making sure to get the wires right, OK?). Now just mount the new valve, reconnect the water, turn the water on and plug it in!
EASY! All in all about a 20 min. job. There ya go! Your fixed. Don't forget to rate this solution, OK? My self-esteem is depending on you. :P
SG
SOURCE: Ice Maker
well ur refrigretor is;nt producing enough gas to produce ice make sure u hire some expert who can examin and solve it.
