Question about Maytag Neptune FAV6800AW Top Load Washer
How to remove agitater from maytag washer - Maytag Neptune FAV6800AW Top Load Washer
Remove the top cap(s), there should be a nut under it that holds the agitator in place. Remove the nut and pull the agitator off. It may be tough to get it out if its never been removed, over time lots of soap, dirt etc.; gets in there and clogs up the splines. Try pouring boiling water onto the splines, if its hard to get off.
Posted on Feb 17, 2015
6ya staff
SOURCE:
How to clean the screen under the agitater
Pull the fabric softener dispenser off the agitator, reach down and pull off the white cover (has 2 ears on it), then remove the bolt holding the agitator to the shaft. It then lifts off.
Jan 28, 2010 | Whirlpool LSR7333 Top Load Washer
Maytag Quiet Plus 4 Heavy Duty ticks when agitating.
no odds are your whole gear casing needs replaced very expensive
May 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
WHIRLPOOL WASHER MAKES A LOUD RATCHETING SOUND
CALL YOUR REPAIRMAN AND SEE IF HE CAN FIX YOUR WASHER FOR YOU. IF NOT, THEN IT IS TIME TO BUY A NEW WASHER. GOOD LUCK.
RODNEY
Apr 11, 2009 | Maytag PAV2300 Top Load Washer
Kenmore 90 series washer 110.28902790
if you remove the agitater cap and the inside cap,you will see what they call dogs(4 of them)they wear out and the agitater will not wotk,if you remove the 7/16 bolt and pull the agitater off you can replace them and all will be fine,you can get them at your local appliance part store,please leave me a fixya-mike
Mar 12, 2009 | Kenmore 15864/15862 Top Load Washer
Maytag washer fills but doesn't agitate
I took the control panel off and played with the lid switch a little and found the agitater would work intermittently. I bypassed one of the switchs (it appeared to have two switches mounted on a plate) and the washer would work properly. I used information I found on RepairClinic.com to help understand my problem and see a picture of the switch for my washer, so I contacted them to purchase the part. I installed the lid switch assembly and it now works great.
Mar 06, 2009 | Maytag LAT2300 Top Load Washer
My ge washer wpre6100g clicks during agitation part of cycle...
sounds like the agitater drive is stripped its a plastic piece under tha agitater you just grab the agitater work your fingers under the edges and **** up on it and it snaps off then remove the 5/16 screw put a new block on and snap the agitater back on
Jan 29, 2009 | GE Profile WPRE6100G Top Load Washer
Kenmore 4025090 washer spins but will not agatate
problem solved ,agitater dogs were broken up inside the agitater hub replaced these and works fine now ,
Dec 10, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Maytag Atlantis 6451 Stops abruptly at end of rinse cycle
sounds like the brakes squeal to me is that the end of the cycle if it is i would worry about it brakes do that not worth the effort of dealing with
Jan 27, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Locks while agitating maytag a 208
its either the transmission itself or the upper bearing. most often its the transmission
Nov 20, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
171 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
