It just started doing this slow, stop and start thing, yesterday. I thought maybe it may be a fuse. I hope someone truly is on the other end of this message. Thank you for your time. Nim
SOURCE: Wateroverfill
sticky level indicator...still a mechanical issue..check to see that it's not stuck or impeded(it's under the washer, up against the tub..usually on one side or the other.
SOURCE: maytag performa dryer doesn't fully heat
A couple of suggestions. STOP, be sure the gas it turned off before disconnecting the line. Move it to an open area and check all venting. A good cleaning makes a huge difference. I believe your problem to be the heating coil is on it's way out, "works sometime". Write down the Make, Model, Seriel Number & Year of MFG...someone may ask for it..Check Your local appliance store for price & availablity Easy to replace on most model dryers.
When reattaching the gas line, be safe not to overtighten the coupler. A safe test for leaks is NOT a match... a drop or two of dishsoap around the fittings will bubble if it is not sealed. Good Luck
SOURCE: Dryer stops after 20min. maytag model lse7806ace
Sounds like it's overheating, when is the last time you cleaned the vent. You should peridically (at least every 6 months) disconnect the vent pipe/hose at the back of the machine clean it in both directions with a canister vac. Also make sure the vent 'exit' on the exterior of your residence which has a flap isn't plugged or stuck in the closed position. If this doesn't help let me know and I'll be glad to help you further.
