Remove A Cmos Battery From A Compaq V2000 Laptop
The Complementary Metal-Oxide Semiconductor (CMOS) in a computer is responsible for storing hardware settings and time on your computer. The CMOS is powered by a small battery and is able to store information whether your computer is turned on or off. While the standard CMOS battery lasts for up to ten years, you may need to replace your CMOS sooner than that. If you password your BIOS and forget the password or need to reset your configuration back to the default, you can remove the CMOS and re-insert or replace it.
Instructions
1. Unplug the computer from the wall outlet and unplug the AC adapter from the computer.
2. Turn your Compaq Presario V2000 face down and slide the battery release latch to the left to disengage the battery from its position. Remove the battery.
3. Unscrew the screws over the hard drive cover, which is located in the lower right corner of the laptop if your laptop is placed with the battery away from you. Lift the hard drive tab, located on the left side of the hard drive, and slide the hard drive to the left to remove it from the computer.
4. Unscrew the single screw located directly under the optical CD/DVD drive. Insert a very thin item, such as a paper clip or pin, into the hole located on the optical drive to open it. Slide your optical drive out of its tray to remove it.
5. Remove the two screws located on the switch cover, which is directly under the battery. Turn the computer right-side up and open it as wide as it will go. Use a flat tipped screwdriver to lift up the switch cover that is directly above the "F1," "F5," "F11" and "Insert" keys.
6. Unscrew the four screws that hold the keyboard in place. These screws are are located in the upper right corner of the computer under the switch cover that you just removed. Lift the keyboard up and slide it forward until it rests on the palm rest. Unplug the zif connector, which is located directly above the palm rest, to disconnect the keyboard. Lift the keyboard up and out of the laptop.
7. Turn the computer upside down again and remove the memory modules by unscrewing the two screws over the memory compartment located directly below the battery slot. Unclip the two clips located on each side of the memory module to release it from its slot and slide it out of the computer.
8. Unscrew the two screws on the PCI cover directly beneath the memory module. Disconnect the two wireless antennas above the card. Spread the two clips securing the mini PCI card into place and lift the card up and out at a 45-degree angle away from you.
9. Flip the laptop back up on its right side and disconnect the display cable located in the upper left corner above the keyboard area underneath the switch cover you removed earlier. Then remove the two pieces of tape in the upper right corner that hold the wireless antenna in place. Remove the two clips located beneath the tape pieces. Unscrew the two screws on the upper left corner and the two in the upper right corner that hold the display into place. Remove the display assembly.
10. Turn the computer back upside down and remove the remaining 19 screws. Lift the base enclosure straight up out of its place.
11. Locate the CMOS battery, a small circular object, and lift it up out of its place. Leave it out for five minutes and reinsert it to reset your settings. Re-assemble the computer without the battery and plug it into the wall.
Remove Cmos Battery From Compaq V2000 Laptop
SOURCE: drivers for HP Compaq Presario V2000 laptop
link to v2000 CTO
link to V2000 support page, you select which series, click on it then select which operating system you are using.
you can download drivers from here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&lang=en&dlc=en&product=500508&
may this help,
melnavz
PS:pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
SOURCE: how to resets bios for compaq 2514 at
Why? What happend? Is it asking for a BIOS password?
If it is asking you have to short two jumpers on the systemboard to have it reset.
If not, just go in to BIOS by pressing F2 then restore or optimize default settings on BIOS.
Hope this helps...
pls send compaq notebook presario v2000 audio driver
http://h10025.www1.hp.com/ewfrf/wc/pfinder?lc=en&dlc=en&cc=us&query=Presario%20V2000%20&dest_page=softwareCategory&tool=softwareCategory
You will find the drivers you need there!
Just select one of the 3 V2000, the one YOU have, then select your OS, download all the drivers you need.
Good luck to you!
Please take a minute to vote
Nic
