Makita Hm1500b 42-pound Demolition Breaking Hammer Logo
A
Anonymous Posted on Jul 02, 2014
What part grease to use for makita hm1500? - Makita Hm1500b 42-pound Demolition Breaking Hammer
Pieter Vleeshouwers
Level 3:
  • Makita Master 2,029 Answers
  • Posted on Mar 16, 2016
Pieter Vleeshouwers
Makita Master
Level 3:
Answers
2029
Questions
0
Helped
4112494
Points
7389
30 grams needed order nr its a grease with ordernumber 181490-7
And 193403-6 is the service kit for this machine.
1 Related Answer
Repair Ahjoshe
  • 885 Answers
  • Posted on Jan 20, 2012
SOURCE: Where do I ad oil to a makita hm1500 demolition
Go to http://www.makitatools.com/en-us/Modules/Home/Default.aspx, put your model number in search box in the top right. Two models of the HM1500 will come up, select yours and open the owner's manual. Find the paragraph labeled 'Lubrication' and follow it precicely. Demo hammers are very picky about what type of grease they use and how much. Too thick and they won't work, too thin and they won't lubricate properly and the parts inside are very expensive to replace. Same applies to how much to use.
Does a makita electrick. Jackhammer take oil or grease and where does it go
The GREASE for this heavy jackhammer
Makita 181490-7 Grease (if there are short carbon brushes to find ) replace all orings gaskets (and looking for an maintenance kit for this machine) 188015-8 thats the better way to service.
What type of oil shall be used in makita hm1304 demolition hammer?
You require Hammer Grease, All good tool shops should have grease to suit. see link below:-
Hammer Grease 90582 for Makita Power Tool eReplacement Parts
What type of oil
http://www.homedepot.com/p/Makita-Hammer-Bit-Grease-194683-7/205182387
For outside chisels
Inside its depend on the model but most time its a Makita 181490-7 or for the older types Hammer grease Makita P-08361
What grease do you use for a makita demolition hammer
MAKITA HAMMER DRILL GREASE 30G (181490-7) or for the older HM models Hammer grease Makita P-08361
1helpful
2answers
Where do I ad oil to a makita hm1500 demolition hammer
1helpful
Where do u as oil in makita 1500 jackhammer?
Makita 8406C Gearbox oil
It uses grease to lube the gearbox. makita supply their own grease so you should be able to get a small tube from your local dealer. You don't have to use Makita grease though, just general grease should be fine. Not too thick and heavy, or too oily and light. I know that sounds a bit vague. Do you have other machines that you have grease for? SDS hammer drills, saws, any small power tool like that will use a similar type of grease.
Nov 01, 2008 • Drills
Top Makita Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Makita Hammering Expert? Answer questions, earn points and help others
