The LG AKB73615337 remote control is designed specifically for LG TVs and may not be compatible with the Xfinity Flex box. However, you can try the following steps to see if it works:
Ensure compatibility: Confirm that the LG remote control is compatible with the Xfinity Flex box by checking the list of supported devices in the remote control's user manual or by contacting LG customer support.
Power on the Flex box: Make sure your Xfinity Flex box is powered on and connected to your TV.
Activate pairing mode: Put the LG remote control into pairing mode by simultaneously pressing and holding the "Back" and "Home" buttons for a few seconds until the LED light on the remote starts blinking.
Follow the Xfinity Flex box pairing instructions: Refer to the Xfinity Flex box's user manual or contact Xfinity customer support to find the specific instructions for pairing a remote control. This process may involve entering a pairing code or following a series of steps on the TV screen.
Test the remote control: Once the pairing process is complete, test the LG remote control to see if it works with the Xfinity Flex box. Try navigating the menu, changing channels, adjusting volume, and performing other functions to ensure proper functionality.
If the LG remote control does not work with the Xfinity Flex box or if the pairing process is unsuccessful, it is recommended to use the original remote control that came with the Flex box or consider purchasing a universal remote control that is compatible with the Xfinity Flex box. Universal remote controls are designed to work with multiple devices and usually come with instructions for programming them to work with specific devices.
Remember to consult the user manuals of both the LG remote control and the Xfinity Flex box for specific instructions and contact customer support if you encounter any difficulties during the pairing process.
the problem is
from the flex that connects your screen to the phone's main board. This
flex must have worn out that's why your screen is not displaying any
picture.
The problem is common with flip and slide phones. The
flex gets worn out as a result of constant opening and close of the
flip or slide phone.
I would urge you to replace the flex and I
am assuring you that your screen will display picture again. You might
also be lucky to find out that the flex is not well fix, that is, it
may have loosed contact.
If you cannot change the flex yourself,
maybe you should take the phone to a local repairer within your
vicinity, so that the flex can be fixed/replaced.
when a screen goes blurry, it is been caused by the flex of the phone.
The flex of the phone is connected to the board of the phone and o the front board that makes the screen displays.
The flex might have shifted from the position it was, so you need to loosen the phone to adjust the flex, after adjusting if the flex still did not show, that means the flex will need to be replaced with another one.
i would advice that if you can loosen the phone, you can take it a mobile engineer to prevent further damage on the phone.
I have questions about the symbols on our new LG GB255g (Madison). The manual gives no picture of the symbols, and LG Canada's tech support line told me, "If it isn't in the manual, I can't tell you." While some symbols are pretty obvious, (signal strength, Bluetooth), there are others which are not obvious, and I am surprised there isn't better access to LG's manuals.
