Panasonic Viera Model # P42S30 remote does not work; turned on using power model on the TV; red LED power indicator flashes 14 times then cycles again for 14 times
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
SOURCE: Panasonic viera Plasma TV model TH-P42X10A The tv
The power supply board of the television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
SOURCE: hi mate i have a
hi good day welcome to fixya
lets verify first to narrow down where the problem came from, now when the indicator is flashing then doesn't steady to green that is mean their is something error detected by the main board that is why won't turn on. at this point you will need to apply trouble shooting so first you need to open the back cover of the tv unit to access the internal part make sure you have the proper tools and device. now turn the tv on then while the indicator is flashing you need to check the output voltage of power supply if all present the 5v stand by,5v switch,12v and 24v. then check the PS_ON voltage from the main board going to power supply if not available their is a problem with the processor. then at the same time you need to have a INV_ON voltage going to inverter ballast if also no voltage around 3.3v then it was confirmed you have bad processor. check also bad component at inverter ballast a shorted component will cause the main board to shut off. hope this will help just let me know if it works thanks for consulting the fixya.
