SOURCE: have a coleman powermate 5000. Won't start. Laid
Cleaning the carb bowl is not enough make sure you pull out the main jet and clean it out real good. If it starts with starting fluid then it is definitely a fuel problem.
SOURCE: I'm looking for an owners manual for a Coleman Powermate 4000
You may not be able to find the owners manual, but if you search using model / type #s off the engine, you may be able to find the manual for the engine from the manufacturer.
SOURCE: Coleman powermate starter pulley broken
Take the pulley to any auto parts store and they should be able to match it up. good luck.
SOURCE: generator runs, but doesn't produce electricity
Manuals and part lists:
http://www.powermate.com/productmanuals.php?cat_id=3
Contact information:
http://www.powermate.com/contact.php
Your question is...?
