Whirlpool Duet GHW9150P Front Load Washer Logo
A
Anonymous Posted on Jul 02, 2014
How big should the washer be to wash a queen size comforter?
2 Related Answers
Anonymous
  • 432 Answers
  • Posted on Nov 04, 2009
SOURCE: I startedt to wash a comforter in my washer. When
Try running the comforter again.
Anonymous
  • 3 Answers
  • Posted on Dec 03, 2010
SOURCE: \\\my washer flashes a F 21 and doesn't open. I
Your blanket probably caused an out of balance on the tub which caused the washer to stop in the middle of the cycle. The lock switch is a time delayed switch. Requires several minutes before it is activated to release. When washing single items you need to add another clothing item of approximately the same weight to create a balance during spin.
2answers
Washing queen comforter?
An unknown make and model of an unknown style!!
So the answer is that it is impossible to tell you. However, lets make some guesses.
If you have a compact apartment type machine, no because it is just TOO small.
If it is a top loader, the answer is no, because the agitator won't move it, because it is all one piece.
If it is a full size front loader, maybe. As long as there is warm water, it will refresh and clean it. You say properly though. To clean 'properly' to get rid of soil, or needs to have room to tumble in the water. For that you need an industrial size machine at a launderettes, or take it to your local dry cleaner, they can dry or wet clean.
finally, Google
make model manual
They are all online. www.manualslib.com is particularly good. Ignore any website that ask you to click to prove you aren't a robot, or any that say to enter your credit card number to prove you are a real person.
I have a Kenmore washing machine that stopped working while washing a king size comforter. It looks likt the comfortor may have got caught on the agitator. I can hear a sound coming from the motor area...
The comforter is too big for these washers. But it sounds like you may have taken out the motor coupler. It's an easy fix. If that's not it, then the transmission broke. But it is more than likely the coupler.
2answers
Kenmore washer leaking
you probably have a bad pump. I am on my 3rd one
What is the capacity (Size) of the Speed Queen Marathon Washer?
Pi,r,squared times height. Remember math back when we didn't have computers? So that's 3.14 x radius(half the distance across drum)squared(times itself) times height or depth of drum. Remember to do radius times itself first, then Pi, then height.
2helpful
3answers
Can I put to wash the comforter in speed queen washer swt912wn?
2.8 cu. ft capacity
you can wash a king sized comfortor in it.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Washing down comforter
It really depends on how big the drum is. It needs room to wash properly, so if there is no room - I would say it's too big.
Try your local laudarette - they have industrial machines that are designed for large items, so to save yourself a repair bill - just use them.
King down comforter
I tried washing a queen size comforter in my washer and blew the boot out of it. 250.00 repair bill. Go to laundymat!
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
