SOURCE: download manual function guide of canon power shot A470
Hi - You can download the manual from the link underlined in blue below:
power shot A470
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
SOURCE: Canon Power shot sd 1000
what u have to do is when u are going to take the picture click on the little lightening bolt next to the func. set button. 2 pictures will pop up- one of a lightening bolt and another with a lightening bolt with a slash through it. hit the lightening bolt button again and it will select the slashed lightening bolt picture. this will turn flash off to turn it back on go back to the screen with the 2 bolts the same way but press the button with the flower to the right of the func. set button.
SOURCE: I have my canon a470 digital camera, recently i
This sounds like a stuck shutter, with the shutter stuck open. See this link, trying Fix #5A. If Fix 5A does not work, your camera is then likely experiencing a broken ribbon cable to the shutter control. Unfortunately, repairing that cable would be more costly than the value of the camera. Also, repairing the cable yourself is not recommended as finding a replacement cable would be just as costly, and the actual repair is very difficult.
SOURCE: I dont know how to
You have to unprotect it first. It's a bit confusing because the menu item probably only says "Protect..." but it also takes care of unprotecting too. Go into the menu for "Protect..." and navigate to the protected one. Whatever button you press to switch the protected status (it's the SET button on my Canon) you can use it to turn the protection off as well. When you exit the protection mode, you can delete it.
