I use Thomson ST585 v6 which automatically connects my desktop, but do not know password to allow visitors to connect their laptops, can I retrieve this, or can they connect if I press the black button on...
The black button on the front panel of 585's is to enable / disable the wireless network (WiFi). If the WiFi is enabled with a password setting the led on the front panel is green, if the WiFi is enabled without a password setting (free to all) the led is red. If your desktop is connected with a cable at 585, you can just use the button in order to enable (or disable) the WiFi for the visitors. If you want something more secure you can set the WiFi with a password but in this case you must tell your visitors the password in order to acess the WiFi. It's up on you to decide the way you want to use the WiFi. Of course if you need help to set up the WiFi password post me a reply.
In case of a problem or clarification, don't hesitate to post me a reply also.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
