Replace thermostats. If problem continues, replace elements
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If water heater flooded, replace heater
http://waterheatertimer.org/Floodedwater-heater.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: New water heater installed in Jan.2010, first no
The reset switch works like a thermostatic breaker and although unusual, it is possible the reset switch is bad or weak. You can replace the reset but some are hard to find. It may be easier to replace the upper thermostat with reset. I would also suggest that you check with the vender you purchased it from, and relay your story to them as they may be willing to help you with the parts. I hope this helps.
SOURCE: hello, i have a reliance
Replace both thermostats and test both elements.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Problem has to be bad element or bad thermostat.
Test elements for short to ground through metal tank wall:
Make sure factory-installed insulation and cover are re-installed over new thermostats so they do not misread tank temperature.
If problem does not show with elements, then replace thermostats again.
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for Electric Hot Water Heater
heatman101
