click on account, should be a help menu, in that a frequently asked question will take you to the delete option, after you pick delete or cancel it will take 48 hrs before it goes thru
Feroza. Loosing a password is as bad as loosing the only key to your front door. Loosing equals forgotten. Facebook has a lot of ways to recover your account, but you should have left at least one email account where you still have access to, before you last connected to FB.
They even can send a reset pass word code to one of the first e-mail addresses you used to verify you were a real person and not a bot. Remember you had to open a mail and send back a number, or click a link while setting up your account.
I'm not sure you tried to get help from Facebook, but if not, go to this page and see if anything fits your situation, to recover your account. Facebook Help Center Facebook
if you di-activate your account then all you have to do is login. But if the account is totally disabled you must register another account co'z what i've know that once your account is totally di-activated you can no longer retrieve all the files that you have uploaded or even open the account. Better to ask the admin on facebook. Just a thought hope it helps thanks.
Since you can no longer get the email adress again then i suggest that you open a new facebook account with the email address and password that you are familiar with that is the one you remember
Sorry to hear about the trouble you are going through. Each facebook account has unique login information. What does this mean? Well, this means that you have two accounts and each account has unique login information. You can't login to one account with the login details from the other account. You can't use the same email address for two accounts. You may have deactivated the wrong account.
When you go to log in to your facebook account it ask for your email and your password. You will need to enter in the email address you used to create the correct account. It should be as simple as just entering in your email address and password to get to the right account.
There are a couple ways you can go to fix this. The easiest would be to reach out to facebook support and have them(I recommend) to delete the accounts and you start from fresh. They may be able to re-activate the correct account if it was deactivated.
Go to this site and reset your Yahoo! password through the prompts provided. Afterwards, you can go to this site and reset your password for facebook. Hope this helps.
I would go into facebook and use the "forgot my password" Option.
There you will be asked to answer some questions.
These are there to see if you are the real owner to this facebook account.
If you still have issues. You can simply just create another facebook account. and get your friends to add you again. You add your friends - your friends see you have a different facebook account. they add you. You've got your account the same way it was before.
I hope this helped :)
Sounds like your account got hacked or simply lost. Did you try contacting Facebook customer support? Ask then to retrieve it from backup on last day you remember having the account.
