Kyocera Copystar CS-1820 Black and White Copier Logo
A
Anonymous Posted on Jul 03, 2014
What should i do my KYOCERA FS-1125 Mfp gives error code C0190
5 Related Answers
Anonymous
  • 56 Answers
  • Posted on Nov 06, 2007
SOURCE: Kyocera FS-2000D
Hi, Sound like drum unit is out off position.
Switch off printer.Open left side door, remove waste toner bottle and push drum unit(with grej lever on it) in printer to proper position.If grey lever is not in proper position, drum will be not locked.Place waste toner bottle in position.Switch on printer.
A
Anonymous
  • Posted on Dec 18, 2007
install new firmware
Anonymous
  • 66 Answers
  • Posted on Mar 10, 2009
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Anonymous
  • 300 Answers
  • Posted on Apr 14, 2009
SOURCE: CALL SERVICE 6000:0115785
Error 6000: is a fuser error 0115785 is your page count. You require a replacement fuser
Anonymous
  • 241 Answers
  • Posted on Jun 09, 2010
SOURCE: kyocera fs-3900dn showing 7410:0024216 error code
The 7410 is a drum installation error code. This is typically caused when the waste bin is replaced. Open the left door and push on the drum unit just above the waste bin, usualy a click will be heard when pushing it in. Then power cycle the printer. This should fix the error message.
Hi, I have an error code C7990 on a Kyocera FS-1028 MFP. Can someone help me on translation and fix of this error?
empty drum unit its full of waste toner each side of drum unit has plastic covers that pop off empty out the unit thoroughly and vacuum inside
2answers
How i do fix code error 245 for kyocera 6525 MFP
Upgrade to the latest firmware of the FS-6525MFP.
Call service Code 4600 KYOCERA FS 8520 MFP
LSU cleaning motor error
When the LSU cleaning motor
is driven, an error signal is
detected continuously for 1 s.
Defective connector
cable or poor
contact in the connector.
Reinsert the connector. Also check for continuity
of the connector cable. If none, replace
the cable.
1helpful
KYOCERA FS 1118 MFP SHOW ERROR CODE C6000 WHAT B I CAN DO
replace the fuser will fix that. Or if you want to stip it down check the lamps and if their ok change the thermistor and thermostat. But your better off just replacing the whole unit
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
1helpful
Fs-1118 mfp printer error code c3200 for solustion
UNLOCK THE SCANNER LOCK SWITCH ON THE PRINTER WORKING.
3helpful
Error de llamada 7980 en kyocera fs 1016 mfp
5helpful
3answers
Kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
2answers
Kyocera FS1118 mfp gives error code CF 040 after start up
do a google search for the service manual and then lookup the error code in the service manual
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
