Are you running under a limited account? If no, you may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs).
A. If your computer will boot and you can operate it ok...
Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found.
B. If your computer won\'t boot, or can\'t operate properly after boot...
Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found.
C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.
Good luck.
G
SOURCE: windows doesnt start
you need to restore your boot system by booting from windows installation disk.
whenyou boot fron CD and ask for repair , select install windows
after you accept the disclaimer by pressing F8, installation will search for current windows installation
after the search select RESTORE
SOURCE: error code 31 4 to 6 network adapter
Check these things:
SOURCE: I have an HP Pavilion Elite m9150f desktop PC.
Could be one of two things: either the BIOS has lost the settings for the hard drive, which is uncommon unless the PC is more than 5 years old or been electrically shocked, or the hard drive is going bad. hard drives usually only last about 3-5 years on average. Western Digital even less.
SOURCE: computer shows no display
did you try installing newest drivers from intel/gigabyte website? what you described looks to me as a overheating problem. try running the game with case open. are you running on the integrated GMA graphics or PCI-E graphics card(like geforce, radeon)?
SOURCE: BIOHD-5
hello there
depending on the error code it is hard to determine what the problem is
but here is a link that should cover almost all of the codes
