Could you please tell me the age of this machine, thank you.
SOURCE: F/P Excellence 6.5 smart drive 9
Your inlet valve could be clogged, check this out.............
SOURCE: Cleaning washing machine
pull dispenser up and off lossen large plastic wing nut in bottom of agitator throat lift agitator off if you wish to remove basket pull plugs out front corners of top remove phillips screws lift top up remove agitator as described remove ring on top of basket it just snaps off lift basket straight up
SOURCE: model GW609NZ f&p washing machine/smart drive 6.5kg excellence
Dear herman worth and Guest also!,
ngfam1 here for you!
I am happy to be of assistance!
FIX IT NOW BEFORE IT GETS WORSE AND COST MORE!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Pleas egive me a good rating here in fixya.com before you sign out!
SOURCE: hey, my f&p smart drive 9 excellence washing
Is the bowl turning slowly when you press start.if it does then you may have a faulty inlet valve,make sure taps are turned on.try advancing the machine to spin cycle,see if it will do any other things such as spin & drain.if it does then probably just not letting in water & inlet valve needs replacing..try filling machine by hand & see if it washes.
SOURCE: i have the fisher &
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
