SOURCE: GE frig just starting leaking water at the bottom of the freezer side door
The water on the floor below the freezer door is due to an inadequate door seal. The door is not closing completely, either a foreign object at the bottom, or more likely, the freezer door gasket needs replacing.
SOURCE: GE Side by Side Refrigerator pss26sgpass - Not cooling
Hello Villaruel,
Welcome to fixya.com
I'll give you some tasks that I hope will solve your problem.
Try turning off the fridge, and unplugging it or throw off the breaker, for 5minutes!
then plug it in and turn it back on. We are trying to reset the system like when you reboot your computer. Let me know that it worked!!
Huuum,
Please do not forget to rate us before you sign off!
Thank You
SOURCE: not cooling
Sometimes when the evaporator fan goes out, it takes part of the motherboard also. (part number WR55X10552, which also subs into a WR55X10656) If this is the case, I would not expect the refrig to be running either. (If your compressor still runs, check door switch.)
SOURCE: GE side by side refrigerater is not cooling on one side.
sounds like ayou could be having a problem with the defrost system pull the back cover off and you will see a metal bracket about half way up the coils and one at the bottom some models just have the one at the bottom these are defrost heaters check and see if one is burned out if so defroset replace heater and you will be ok if heaters are good check at the top of the coils there is a small round thing cliped onto one of the coil lines with 2 wires coming out of it this is a defrost bimetal or defrost thermostat now for this check the bimetal has to be cold and you need an ohm meter it is a simple test when cold it should read close which with and anolog meter will peg the neddle a digital will read 0.0 -0.2 this means this part is good if the needle does not move or you get no reading it is bad replace it now if the heaters and bimetal are good there is and evaporator thermister also located on the evapoator it is a small white look like a small bulett it could be sending the wrong information to the mother board this part is about 10.00 and the mother board on theif you still have a problem im afraid to say you mother board is bad replace it and you should be good to go with out all the snow it runs about 150 - 200 dollars depending on who you get it from.
SOURCE: Fan not working. Turbo cool reads error
Verify you have voltage at your fan. If you have voltage and the fan is not running then it will need to be replaced.
