Kobo Arc Logo
s
stephanie louise Posted on Jul 03, 2014
Need kobo arc flex cable
Where can i buy a kobo arc flex cable ribbon?
Download kobo arc 7 instruction manual
http://download.kobobooks.com/magento/userguides/downloads/KoboArc7/koboarc7_userguide_en.pdf
Feb 12, 2015 • Kobo Arc
My kobo arc 7 screen is not responding to touches. Can it be reset?
1. Turn the power off and pull the battery out and reinsert it.
2. Hold the Volume Down button.
3. Then press and release the Power button.
4. Wait a minute,the menu appears that allows for Fastbook, Recovery, Clear Storage, and Simlock.
5. Ok,press the Volume Down button to choose Clear Storage.
6. Next,press and release the Power button,Wait for the Kobo Arc to restart.
7. You will see the two options: Volume Up for YES and Volume Down for NO.
8. If you choose YES, all data will be deleted from your Kobo Arc and including third-party applications.
9. The Kobo Arc will reboot to its original data.
10. This time you can restore your backed up data to your phone.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_e0539de310ea5ad7
My kobo wont turn charge and turn on
Broken psu connector or moethboard junk it its not cost effective to repair.
Aug 20, 2014 • Kobo Arc
1helpful
2answers
How do i repair the charging port on my kobo arc the cord will not fit?
That's a tough job unless you can send it back.
You can charge it with a USB cable and aPC, however it is slower but it might work.
Try that first.
May 17, 2014 • Kobo Arc
Kobo arc screen border cracked can I get it fix
Epoxy might do the trick if you can find the same color.
Apr 12, 2014 • Kobo Arc
3helpful
2answers
Mini usb port on kobo arc is broken. Where can I get parts?
Hi i managed fix my usb port , open the kobo and remove the usb ribbon, the usb port is glued at the rear , you will see a black blob od adhesive at back of port , this comes unstuck if it gets a knock , i gently lifted this slightly then slid some super glue underneath and then applied pressure on top of the usb port to ensure the port was contacting the ribbon again until the glue set, my kobo is back in action again , hope this helps someone
Jun 20, 2013 • Kobo Arc
2helpful
I need a kobo arc manual
No Probs,
Copy and paste this link.
merch.kobobooks.com/.../Arc/kobo_arc_user_guide_en.pdf
Nov 18, 2012 • Kobo Arc
Top Kobo Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Kobo Tablet and eReader Expert? Answer questions, earn points and help others
