Janome Memorycraft 6500P Computerized Sewing Machine Logo
A
Anonymous Posted on Jul 03, 2014
How to time memory craft 7000
How to adjust timing
Anita
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 63 Answers
  • Posted on Aug 29, 2014
Anita
Contributor
Level 1:
New Friend:
Cheetah:
Answers
63
Questions
0
Helped
11120
Points
86
Your manual should have directions if you don't have please us your search engine on your computer put in model + name+ number + manual + free
5 Related Answers
Anonymous
  • 1952 Answers
  • Posted on Jan 04, 2009
SOURCE: Janome Memory Craft 10001
Are you checking the simple things such as making sure you have the presser foot up when you thread and the tensions set between 4 and 6, bobbin in the correct way round and tension enough to pull the thread through with some resistence.
Anonymous
  • Posted on Jan 18, 2009
SOURCE: Janome Memory Craft 7000 Sewing
My Memory Craft 7000 sometimes does the same thing, if it's very cold. Try warming it up by placing it near a heat source, a vent or a floor heater, for a few minutes. Then it works perfectly.
I've used these machines for over 20 years now, and they're my favorite!
If this doesn't solve your problem, you need to take it in for servicing.
They are work horses, but they do need their maintenance from time to time.
I hope this helps you.
Anonymous
  • 161 Answers
  • Posted on Sep 13, 2010
SOURCE: Is there a trick to attaching the hoop on memory
usually the hoops just lock on, but make sure you have the correct foot on first and that there is nothing in the way to stop the hoop sitting correctly
Anonymous
  • 161 Answers
  • Posted on Sep 14, 2010
SOURCE: adjusting the dogs on memoery craft 9700
are you trying to drop them for embroidery ? look at the back, behind the bobbin area, there should be a lever. my 9000 also has the option to use ADJ and the grphic for the feed dogs come up. on the 9000, they disengage automatically when you go to embroidery mode. I hope this helps
Anonymous
  • 1788 Answers
  • Posted on Sep 19, 2010
SOURCE: i do not know how
Download a copy of your manual for $10, at www.sewingmanuals.com and you will be able to see it.
Can I replace the Janome Memory Craft 7000 carrying handle with a Memory craft 8000 carrying handle? I am having difficulty finding this replacement part any ideas?
If these two don't carry it, or can't order it, no one can
Janome Memory Craft 7000 Parts and Accessories
https://www.sewingmachinesplus.com > janome-mc700...
The Janome Memory Craft 7000 parts and accessories on this page are guaranteed to fit the Janome Memory Craft 7000 sewing machine or your money back.
Janome Memory Craft 7000 Sewing Machine Parts
https://www.sewingpartsonline.com > janome-memory-...
Shop our extensive selection of Janome sewing machine and serger parts and accessories! Quick delivery. Free shipping over $49. Easy 90-day returns.
Bag with handle
https://www.sewingpartsonline.com/search.html?keywords=janome+7000+carrying+handle
2answers
Where is the memorycraft 7000 new home/janome re set button please
Don't you have a manual? If not, try unplugging and waiting 10 seconds and plug it in again. There is also a clear button. I saw a great demonstration of this machine on www.youtube.com, looks like a very nice machine.
Can I do free motion sewing on my New Home Memory Craft Sewing machine
My sewing machine memory craft 7000 all the bottoms stop and it's says error
1helpful
Memory Craft 7000 making terriable noise
the machine is showing it doesn't need oiling or the manual says
it's a self oiling machine?
if the machine is self oiling the DON"T oil the machine.
if you think the noise is from the tension dial,, the try using a can of
air or unwaxed dental floss on the tension dial if you have access
to the tension dial.
or the machine may need to be checked to find why it's making the
noise. the machine may just need some adjustments or a tune-up
depending on when the machine has been serviced last.
Memory craft 7000
Congrats on your MC7000.... now.... do you have an issue you need help with?
I do not know how to replace the needle in my memory craft 7000
1helpful
Is there a trick to attaching the hoop on memory craft 7000
1helpful
Janome Memory Craft 7000 Sewing Machine- When I turn the machine on it moves the needle position slightly and message comes up Err 4, then it freezes. Any clues ????
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
