Toshiba REGZA 47HL167 TV Logo
A
Anonymous Posted on Jul 04, 2014
No sound no picture toshiba tv
Tv has no sound nor picture and keeps saying mono?
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Mar 02, 2008
SOURCE: 42" Toshiba Plasma TV no picture or sound
My experience with 42" plasma tv's with no picture or sound was a missing power supply voltage. On the power supply board check voltages on the plug. The voltages should be marked on the board,
Anonymous
  • Posted on Oct 05, 2009
SOURCE: My 32HL57 model tv has sound but no picture?
en francais
le modul est fixé sur l'ecran
sur ce modul verifier si vous avez 3.3 volt (trois regulatuer avec un test point) si vous n'avez pas 3.3 verifier les deux fusibles F1 et F2
F1 devrais etre ouvert ....
bonne tv ;)
module is fixed on the screen
this modul check if you have 3.3 volts (three regulatuer with a test point) if you do not have 3.3 Check both fuses F1 and F2
F1 should be open ....
good tv;)
Anonymous
  • 1284 Answers
  • Posted on Nov 05, 2009
SOURCE: Toshiba 26LV610u TV with no sound on one channel
If you have lost sound on only one station and are using cable or an antenna directly to the TV. Look in the audio settings as most likely the SAP mode is turned on. If the TV detects a SAP signal even if there is no audio this is what you will end up with.
Anonymous
  • 245 Answers
  • Posted on Nov 20, 2009
SOURCE: no picture, no sound. tv less than oone year old.
GO IN TOUCH WITH TOSHIBA AS THE SET WILL BE UNDER WARREN TIE ........SO FREE REPAIR AND SERVICE
Chi Chu
  • 8457 Answers
  • Posted on Jan 08, 2010
SOURCE: 42" Toshiba Plasma TV wonn't turn on
Power board require changing.It dead.
How to put tv in video mode instead of mono
I am confused wit the question. Mono is an audio setting. And video setting are for just that. video.
My toshiba tv has no sound,what is causing it to malfunction
I have a Toshiba 52HM95 the red light and the green light keep coming on but I get no picture but I can hear the sound very good what could it be please help
1helpful
How do I retune My toshiba ct 90240 hd tv
Just download the user manual to your tV from internet. It will have all the details. Get into 'toshiba.com/download/manual' site.
I cant hear sound out of it and i can see to get a picture is there a special code i need to enter for the tv with the remote
Please try pressing at the remote control the MTS botton until STEREO or MONO mode is active.
Toshiba 40xf355d 40inch Plasma tv won't turn on it just makes a clicking noise. thez no picture or sound? my tv powers on and makes a clickin sound but i dont get picture or sound its stays black i have...
That model is an LCD that uses a backlight. Probably with CCFL tubes. They are known to have bad inverter supplies. Its an old TV though. Keep that in mind.
1helpful
Toshiba TV sound vanished
It is possible that the TV set has an SAP (secondary audio program) setting that has been turned on. To check this go in the the menu, find audio settings, usually the correct setting for this is Stereo, other setting may include Mono, Surr-Stereo, etc.
Mono/stereo keeps flashing on my TV screen. How do I fix it?
so for us not using cable for this, what do we do? even plugging a game console into this plug will have same results. keeps switching from mono to stereo making the sound stutter. why does the TV get to decide on its own? who thought of that? is there a setting to choose for it so it doesnt have to bother?
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Mono - no sound
Your remote may have a "mute" button on it. If it does then the button may have been accidentally pushed.
Also in the menu there may be a setting to turn off your speakers.
Some sets also have an external speaker switch which will turn off the speakers to let you connect an external amplifier to the set.
Stargazer
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
