Get larger font on this computer
This amazingly easy trick will instantly enlarge hard to see text on your screen! Should you ever want to decrease the text, this trick in reverse will minimize text as well!
Spending lots of time online can cause eyestrain, especially if you encounter very small text. Don't squint or hunch over your screen! Squinting causes wrinkles! Using these tips you can read screen text comfortably! With the press of two keys, you can enlarge the screen text without going into your settings. Simply press and hold down the "control" key, while pressing the "plus sign" key. Be sure to keep the "control key" depressed while you press the "plus sign" key. Each repetition will enlarge the text. This can make reading small text SO much easier! To return the text back to its original (being polite to the next user), simply press, and hold down the "control" key and the "minus sign" key. Each repetition will decrease the text . also Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar this will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
and text s largest to smallest
Hope this helps.
