SOURCE: error code c6400 on fs-1118
fuser temperature over /under u need service engineer to reset it
LSU cleaning motor error
When the LSU cleaning motor
is driven, an error signal is
detected continuously for 1 s.
Defective connector
cable or poor
contact in the connector.
Reinsert the connector. Also check for continuity
of the connector cable. If none, replace
the cable.
Scanner carriage error
The home position is not correct when the power is turned on, at the end of a reading process of the table and document processor.
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
C0100. Fs3140
