Question about Comfort-Aire BHD-501 Dehumidifier
Why won't my dehumidifier run - Comfort-Aire BHD-501 Dehumidifier
Won't run
Check operation of the interlock switch for the condensate collector. I had a dehumidifier that would not run unless the collector was shoved in and held in place
Dec 29, 2012 | LG LHD65EBL Dehumidifier
It does run yet won"t heat up!!
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 08, 2011 | Crosley DCW25-1 Dehumidifier
Compresser on the bottom gets very hot won't work
heatman101
Jul 19, 2011 | Whirlpool AD25BBK Dehumidifier
I have two of these dehumidifiers. They won't go on automatically. I don't understand the settings. One of them won't stay on at all. It runs and then shuts off.
As per your problem, that the dehumidifier shuts offautomatically - If yourdehumidifier froze, the compressor will shut off automatically. Allow the iceto melt before emptying the tank and restart the dehumidifier. Hope this will help you. Good Luck.
Jul 08, 2011 | Haier 65-Pint Dehumidifier
Compressor won't start,can hear circuit breaker clicking out. Fan runs okay,gauges reading okay.
heatman101
Jun 06, 2011 | Fedders A7DH45B2A Dehumidifier
My matag dehumidifier Model M7dh45b2-a won't even turn on
heatman101
Jun 05, 2011 | Maytag M7DH45B2A Dehumidifier
My dehumidfier won't shut off. I check everything out and it's good but it just won't shut off it keep running.
It may be, that you have it running in continuous mode, rather than timed mode. Also, most dehumidifiers fans will run almost continually, to keep the air moving, so the humidity sensor can pickup and increase in humidity, if there is one.
If the above doesn't seem to be the problem with your unit, turn The Master ON/OFF Switch to OFF and unplug the unit for 12-15 minutes. This will give the electronics time to reset themselves, if necessary.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 23, 2011 | Fedders A7DH45B2A Dehumidifier
How do i know if dehumidifer is is low on freon not taking much water out of air
Hi, Usually if it is low it will start to freeze up but if you have a freeze control unit then the compressor just won't run much...
heatman101
May 19, 2011 | Soleus CFM-40 Dehumidifier
I have a FDL70S1 Dehumidifier. Unit runs for just a couple minutes and shuts off-blinking bucket full even though no water in bucket. Unit won't stay on
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end.
May 17, 2011 | Frigidaire FDL50R1 Dehumidifier
Comfort-Aire BHD-501 Dehumidifier Logo
90 people viewed this question
Top Comfort-Aire Dehumidifiers Experts
Bill Long
Michael Youngman
Michael Youngman
Tom Chichester
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
