Either your Motor or Motor Control Board(MCB) is faulty.
Try testing your Motor with a Drill Battery:
1. Disconnect the machine's power lead from the power socket, so that there is no power to the machine.
2. Open the Motor Hood.
3. Disconnect the Motor + and - leads from the Motor Control Board.
4. Connect + and - leads(normally Red and Black) to the Drill Battery.
The Motor should turn the Belt.
With the Motor leads disconnected from the MCB, you can connect the machine to the power, Press Start, and if this trips your Fuse Box you know its definitely the MCB.
Only carry out these tests if you are competent.
Lethal Voltages are present.
samsfitnesssolutions.co.uk
