Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Does not spin .makes noise . - Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Noise while spinning
My 90 series kenmore washer. At the start of spin,makes loud clicking noise while it spins. Than it stops after a min. I changed the coupler. Still makes noise.
Jan 05, 2014 | Washing Machines
I have a westpoint washing machine wen it is spinning it make a lot of noise serial number wtw 500. it is a 5kg. can you help me with this problem.
Thanks for choosing FixYa and welcome to the site. You need to check your spin bearing and the motor drive. If the noise is only during spinning, you need to check these. Anytime a washer makes loud noises during spinning, always check the spin bearing and motor drive.
Apr 24, 2011 | Washing Machines
Makes buzzing noise and won't spin or drain
Sounds like something is stuck in the drain pump.  If nothing is stuck in the pump replace the pump.  It won't spin until it drains, so fixing the drain problem will fix the spin.  You can get at the drain pump by taking off the bottom panel.
Dec 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer makes a lot of noise during spinning
we need the brand and the model
but for starters, please check on the links below.
http://forum.appliancepartspros.com/washer-repair/4501-washer-makes-extremely-loud-noise-during-spin.html
http://www.thestuccocompany.com/maintenance/Washing-Machine-noise-during-spin-cycle-169980-.htm
http://www.askmehelpdesk.com/appliances/washing-machine-noise-during-spin-cycle-167960.html
Sep 10, 2009 | Whirlpool Washing Machines
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
Washing machine making crackling noise when spinning
check for some loose items underneath the unit. washing machines normally reverses its rotation when spinning. check if mechanical solenoids pulls the right levers as it starts to spin....
Feb 12, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
161 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
