Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
Bosch humming noise - Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
Bosch #b22cs loud humming
try move it away from what it is touching ,the wall or something else.
Mar 03, 2015 | Bosch Refrigerators
Loud humming noise coming from fridge
sounds like the evap fan is hitting something.. or is loose and making noise... I would remove the cover in front of the fan and take motor out and reinstall it making sure all washers and grommets are in place...but I would look for ice build up first, this could indicate a defrost problem..... hope this helped ken
Sep 29, 2014 | Bosch Refrigerators
Have a Bocsh WTMC 3321US/03 drier making noise. i have replaced motor, same noise. with drum not turning and belt disengaged, making same noise. What do i look for next??
If a noise is heard or even a HUM you can use a small tube to probe with one side kept to your ear. Trace the noise to the actual unit , if this is the motor humming check the capacitor as a faulty capacitor will not start the motor.
Also check for free movement of the motor drive as if there is tightness in the drive the motor will not work.
Nov 05, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch SHV46C
Replace the fill valve that sound is it trying to open
Mar 12, 2009 | Bosch 24 in. SHV46C13UC Free-Standing...
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Broken Dishwasher : Bosch SGS53A12GB/01
dear customer,
For such cases we recommend you to follow the below stated routines..
  • Unjam the motor
  • Unjam the pump
  • Test the motor
  • Test the motor start relay
  • Check the drive belt
  • This usually solves the problem. hope u find this useful.
    Jul 09, 2008 | Bosch Dishwashers
    Bought the display unit and water will not work.
    hi there the low humming noise that you are getting sounds like the fill valve, this could be due to you perhaps not turning the water back on after fitting the new dishwasher or the fill hose being kinked when the dishwasher was put back ,hope this is of some help to you.
    Dec 02, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
    Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
    52 people viewed this question
    Top Bosch Washing Machines Experts
    Marvin
    Marvin
    peter gittos
    peter gittos
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
