I have a 2007 Nissan Quest and I want to play my MP3 player on my stereo but I can get the radio to recognize or see the MP3 player. What size jack does it take to plug it into the AUX plug? What do I do to get my radio to play the songs on the MP# player?
You said CAN , i bet you meant CAN'T or CAN NOT. right?
the AUX port is just a line input, analog audio input,
it dont know MP3 .
it only amplies the analog audio found there.
you connect any device, to AUX. push play on the device.
then put car radio in to AUX input mode and play. the audio.
that is all there is to it.
the external device does all the heavy lifting, reading a file, and decoding it (mp3 decode) and then sends raw analog audio out.
the cable is sold and radioshack, or walfart or many other stores,
Target, most MP3 players, come with this cable,
they use mini phone plugs, stereo, type,. (3 contacts)
What is the size of the plug at the stereo end? I think the one I am trying to use is to small so it's not recognizing the MP3 player. Very frustrating ....
ok in the stereo plug H3LL thing, there are like 3 sizes, 1920 phone plugs not, then mini and micro. mini started 1960s with first 3 buck transistor radios. then micro. why not just go to radioshack and show them.? do you own a set of calipers.? id bet not. but the size is in mm. (milimeters) see wiki?
2.5mm , 3.5mm and 3pin and 4 pin. you must find out what yours is. seems its 3.5mm huh, and buy that. but there are 2 ends to any cable and both must be right. at the player and the Radio. both diameter and pin count. (at the least)
if i had the full spec, on both radio and mp3 player, then we could answer. I have no idea what 3 radios are in the quest or even if its stock radio. why not drive to car-audio store and ask for help. it takes EYES on to fix.
if lucky the 3.5mm one to one cable will work its like $4 (3pins)
http://www.bestbuy.com/site/dynex-6-3-5m...$pcmcat143700050032&cp=1&lp=10
this is 3.5mm and double male. and 3 pins, try this. (but pins count) see the end,
this is the most common cable on earth. pretty much. 1960s tech.
SOURCE: Bose Stereo with MP3 capability.
several choices but need little more detail
i will type basics for now
mp3 card slots for memmory
usb connection for flash drive which your zune is considered use the usb cable to connect there
back of sterio special wire connector to hook into what would be considered aux jack these are basics for a sterio
the type of bose you have should be described up for you in basics
SOURCE: Replace 2005 Nissan altima stereo receiver
Try radio shack, or stereo sales/installation place for ready to go plug adapter. For a few bucks, it saves headaches, and butchering the wiring in case you want to re-install old one later when trading in or selling the car.
SOURCE: 2007 nissan maxima will not load or eject CD's...or even play the
Hi, this is a common issue within car CD changers. the load motor go through lots of trauma during the life span that i usually 3 to 5 years. the load motor operates everything in the changer. it works the load tray and spinning of the disc as well. when this motor is out, the changer will be rendered useless. replacing the load motor will fix this issue or, you can just purchase a new changer and save a lot of money.
SOURCE: I need to replace my Nissan Quest 2007 in cabin micro filter
I'm going to send you exploded view of the glove box and the in cabin micro filter cover illustration. Remove the two upper screws on the glove box and carefully pry metal clips loose.
Disconnect glove box lamp electrical connector. Do not let glove box assembly hang from glove box lamp harness.
Remove three lower screws and remove damper clip from glove box door. Separate glove box housing and passenger instrument lower panel.
Remove three screws and remove in cabin micro filter cover.
Remove in cabin micro filters from front heater and cooling unit assembly.
Note When installing two new in cabin micro filters ensure that the filters are facing in the direction indicated by the direction arrow for the airflow. Direction arrow is printed on side of in cabin micro filters.
Install in cabin micro filter cover. Reinstall glove box.
Testimonial: "Finaly I found the air flow door with three screws and removed it. The filter will need replacement soon. It is been replaced one time at the dealer."
