Has finished washing but door locked and will not open
SOURCE: Door will not open
take your lid off were the motor is at the top there should be a cradle with a wire pointing through it there will be a small black clip which stops u from changing the setting it on the underneath of this cradle once you have that out you can push this clip down 1 click at a time each time checking the door to see if it is going to open
SOURCE: Hotpoint Ultima WD71(probably the wd72 except in white)
hi there what u can do is take your drain hose and place into a bucket water will come out the door will release now check the pump and make sure that it is not blocked up with anything if it isnt check the drain pipe that is under the washer in the middle of the drum there will be water in there but check inside if anything is inside there it will slow down the empty programme and will not let the door release do u live in malta then m8 as my dad is maltease and im half
SOURCE: Door locked
After trying all the above, making sure that as much of the water has been removed as possible, you can always use the manual door release. This is located behind the soap powder tray.
Push to open as you would normally when adding more soap powder, pull the tray out as far as you can.
Press down on the yellow portion in the tray and this should enable you to then pull the soap tray completely out.
Once out you should see what looks like a small grey plastic circle with a rectangular hole (ideal for a screwdriver) turn this and your door should open.
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
SOURCE: door stuck shut hot point wd420
It happened on our machine. The soloution to this for me was to take the lid off (two screws). Unplugged from mains. I found the connector to the door had vibrated off and was just hanging loose. Plugged it back in and it worked straight away.Door opens as normal.
Don't forget to look in the manual for how to get the door open in an emergency
