SOURCE: drain line lg tromm
its a pretty complicated process to take off the front panel, you will need special tools for this problem, i would bring it to a professional, the easist way is to lay it on the back side and go from there, if not like stated above bring it to a pro.
ps:drain lines hardly go bad on LG's hmm,if it's leaking then it might be the internal supply lines on the top.
just a hint,
shoots dave
[email protected]
SOURCE: lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
SOURCE: I need to replace roller's on LG Tromm Gas front load dryer
There are 4 screws holding on a plate on the back. It is not the whole panel. Are you trying to get at the ball sensor?
SOURCE: lg tromm front loader washing machine display panel reading l-E.
error code 'IE' means water does not enter the detergent drawer..if your water is hard or contains traces of lime deposits, the water inlet filter may become clogged..regular cleaning is suggested..clean the filter using hard bristle brush..
note: hard water is the one not undergone any treatment..in other words it is directly from the ground through your water pump and to the washer.
SOURCE: My tromm frontload washer is not draining. I
in order to check the main drai hose the whole front panel needs to come come off.This is done by removing the lid.
then remove the screws that hold the main control board, then you need to remove the rubber boot from the front panel.then remove the screws that hold the front panel on the machine.
