The detergent dispenser was not working so I thought I would try cleaning the hoses. I marked on the soap compartmentside but not the valve side. And I think I may have mixed them up. I tried to use common sense and have arranged hoses based on length and fit. Can someone explain the triple inlet's three prongs specific function so that I might verify if I correctly attached or not? Also can someone explain the normal water flow rates throughout the cycles. When does the pre-wash labeled connector/prong on the detergent tray housing fill with water? Thanks in advance.
Um u shouldnt take anything apart if you cant get it back tigether first rule of thumb secondly your description of dispenser doesnt work isnt enough to go buy. Im going to assume the detergent didnt flow in and i will assume u are using tide sport. My guess would be the detergent is too thick to syphin out assuming all that. Try mixing with half water first. Secondly look at the wiring diagram and find the colors of the wires going to each valve then hook hoses up from that valve to the part of the dispenser that has the writing of what your hooking up. Common sense goes a long way when fixing things and or braking them
SOURCE: Water in detergent dispenser
Remove dispencer again, remove conditioner syphon assembly and clean up the little tube. Should then go okay
SOURCE: LG front loader problem
If you remove the top cover you will see the soap dispenser unit on the left. It has a large rubber hose connecting it to the drum. If you remove two screws at the front you can free the dispenser for maintenance. You can undo the clips on the various hoses and check that they are clean.
Some people report some dripping from the soap dispenser even when the hose is unblocked. This seems to be a design fault.
SOURCE: LG WM2277HS - water backing up into soap dispenser
The pipe from the soap dispenser to the tub is quite large, it seems as if the water isn't getting out of the dispenser quick enough. Pull the whole dispenser out of the machine. There is a release clip at the back of the cup with the tray fully open. Clean out all soap residue and scum. Sometimes there is also a spot or setting for liquid or powder detergent. Adjust accordingly. Reassemble and try it again.
SOURCE: Dispenser fills with water.
The reason there is still water in the dispenser, and this in normal by the way, is the unit uses the pre wash and main wash valve to activate the fabric softener. Basically when the two valves come on they force water into the fabric softener compartment. There can be some overflow and it ends up in the blue cup nothing to worry about. Now if you have detergent there, then that is a problem..
Sgt 48
SOURCE: Spots on clothes after washing
Put another filter on before the washer. Try to find out if it is in the hot water or the cold. If it is the cold try a filter. If it is the hot, replace your hot water tank.
Hello royal37 - Hi - The dispenser drawer could either be cracked or have a broken latch due to interference between the drawer front and top panel. Contact a professional to move forward accurately and might possibly need to order a service kit (PN: 137146000/part number may be different depending on your model number).
