The display panel keeps flashing on and off and making a loud clicking noise. It will then work fine for a while and in the middle of the night it will happen when no one has been in the thing for hours. It appears to still be running but we are afraid to keep food in it that may spoil. There are no additional noises or issues.
SOURCE: maytag msd2756de side-by-side: loud clicking noise from top right of refrigerator
sounds like the adaptive defrost controller part number 61005988. not to bad to repace, the top control panel is removed by pulling down on both rear corners ( youls find little finger holes across the top rear panel to free and pulll foward, the n there are 2 1/4in screws across th efron of control, and 2 phillips head screws jus behind each light bulb, one last 1/4in screw directly on back wall will drop entire panel adn after that youl see the control in the right hand corner unplug the old replug the new . DISCONNECT POWER PRIOR TO REPAIR<
SOURCE: 2008 maytag refridgerator tripping my breaker
take it back as it's a fire hazard. Get a replacement.
SOURCE: Noise in upper right (roof) of Frige
Replace the
Maytag 61005988 Adaptive Defrost Timer Assembly. It controls the defrosting od the coils. See below what happens when it goes out.
SOURCE: All display panel lights are blinking,
Bad main control sits on the back of the refrigerator about half way up on the left metal cover. Part number 12920710 double check against model before buying runs $170.
