Frigidaire FTF530FS Front Load Washer Logo
A
Anonymous Posted on Jul 05, 2014
Model FAFs4272LWO won't stop buzzing
It won't stop buzzing
1helpful
Diagram of frigidaire washer FAFS4272LWO
Frigidaire Washer FAFS4272LW0 PartSelect
Go to the above link and you can download manual and diagrams.
Semper Fi,
Z
Why does my frigidaire affinity front load washer model FAFS4272LWO beep every 15 minutes when it is not running?
Bring the unit out of sleep by pressing any button, wait about 5 seconds and the press AND HOLD start/pause and CANCEL an E followed by numbers should appear in the display. Tell us what those numbers are..
F1 button won't stop buzzing
dis connect board wait three minutes and try agin, if still happens, get a new board.
Fridgidaire fafs4272lwo door open error
Make sure the latch is not broken on the door. Retry. If this continues contact a professional so the latch and door assembly can be diagnosed. Also check to see if the door is sagging down at all.
1helpful
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Fafs4272lwo parts diagram
go to youtube and look it up. Basically, you take the top off follwed by the control panel and the front. It is very easy to do.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
