SOURCE: Broil turns ON when pressing BAKE button on RBS275PD Whirlppol oven
Our Whirlpool oven just started doing the same thing!!!! The Delay Start Time (setting it for one minute ahead) and then Start works just fine. But we fried the tops of three loaves of homemade bread!!!!
Is Whirlpool just a bad brand for ovens?
SOURCE: Whirlpool Accubake oven super capacity series 465
In an attempt to self clean my oven, I pushed the auto clean button and then pressed start. Instead, nothing happened, but now have a message on the panel reading E1on the left side of panel and -F5- on the right side of panel. I am unable to clear it or operate the oven now.
SOURCE: whirlpool accubake oven problem
I had the same problem and followed the process listed above....yes, I
did unplug/turn off the circuit and am alive to share this update!
Right off I noticed that the ribbon cable was loose. For those who have
tinkered around with other electronics such as a PC, etc., note that
this ribbon cable is not secured by the connector (atleast in my case).
Reseated the cable and turned the power on. Voila- the bake option
works. Tested it by turning it on for 20-30 seconds. Touched the bake
element and got proof that it was working fine (via a singe of the ring
finger ;-)).
About three minutes or so later, the display started to beep with an
error code - E0 F2. A shorted keypad is what it stands for. The clock
was still operable. I could still select the bake option, broil option,
etc. Ran a test bake cycle but it turned off after a minute or so and
started to display the E0 F2 code again.
Started the process all over ie turn power off, take panel off, reseat
ribbon cable. Turn power on and test by holding the Cancel button for
five seconds. Still displays the E0 F2 error. Waited for 10 minutes but
this time no more beeping or error display. Ran a preheat cycle for 4+
minutes without any problems. The oven warms up and the bake element
glows red. Hopefully, all is well. Will see what it does when we bake
something the next time.
Thanks to PropHeadTwo and others for their contributions.
SOURCE: Maytag oven top heating element won't come on unless on broil
You are probably going to find the lower heating element has failed. Your symptoms describe that failure exactly.
Reply back if you want instruction as to how to repair.
SOURCE: I have a Whirlpool Self
When you use your self clean feature, your oven heats up to over 800 degrees and this normally takes your electronic computer control board out.
