Where is a fuse on eos 30d?
SOURCE: Canon EOS 30D SLR Will Not Turn On...
I seem to recall hearing that the power switch can be a problem on the 30D .. I'm not going to suggest you take it apart to clean the contacts .. better go to a Canon Dealer I think ..
SOURCE: Canon EOS 30D will not operate
Hey Paul
I have the same problems, I just sent it back to Canon Service Center for repairs. I will see what is the outcome.....
SOURCE: my eos rebel says
Look closely at the cf pins inside of the camera. They are usually the problem when you get that error message. I am a Canon repair tech and have fixed three today alone this is a common thing. Look closely at the cf card eject button as well. Sometimes that comes loose and then the card will not seat properly! If you want I can take some pics of what they should look like with the mainboard out of the camera so you can get a idea of what they look like when they are bent and not bent and post them.
SOURCE: the CCD camera canon eos
If you have dirt on the sensor, it can be cleaned using special products. If you Google the words "how to clean an SLR sensor", you will find sites that explain the procedure with pictures and places where you can order the supplies needed. This is much less expensive than trying to replace the ccd sensor.
