Tablets & eReaders Logo
R
Rexton Posted on Jul 06, 2014
Cioecud android forgot unlock password? then to unlock
2answers
I cannot remember my password to get into my tablet
hi John.
i think you will have to do a hard reset to sort this out.
Just tap the Power button to select Reboot System Now.
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset.
More items...
What do I do if I forgot my password to unlock to my tablet? - Trio ...
https://support.triotablets.com/.../201746559-What-do-I-do-if-I-forgot-my-password-to-...
How do I unlock my tablet if I forgot the password?Manual Factory ResetTurn off your Android device. ...Press and hold the "power", "volume down", and "camera" buttons simultaneously. ...Release the buttons once your Android device is powered on. ...Scroll using your "Volume up and down" button until you find the "wipe data/factory reset" option.More items...Recover Android Device in case of Forgot password/pattern unlock an ...visihow.com/Recover...in...Forgot_password/pattern_unlock_an_Android_deviceSearch for: How do I unlock my tablet if I forgot the password?
or before you do anything go to this link and have some more off a read up.
cannot remember my password to get into my tablet Google Search
How to unlock
Deb, You may have to do a factory reset if you can not remember the password. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Forgot your tablets password
Forgotten Pattern PIN or Password on an Android device
What do do if forgot my password to unlock to my tablet
How to Factory Reset Your Android Phone or Tablet When It Wont Boot
1helpful
I need to know how to by pass the password
A factory reset will completely wipe your tablet's memory, and return it the way it was when it came out of the factory. If your device has a removable memory card, it would be a good idea to turn it off and remove the card before resetting, as there is a chance the files stored on here will also be deleted.
press the helpful button and follow me on fixya for more tips and info
below are links to sights that may help
Recover Android Device in case of Forgot password pattern unlock an...
Help Forgot Android tablets password
How to unlock an Android phone tablet
My irulu tablet will not let me open screen without pin#. I was not given one
If it's an android device...
1. Enter wrong pattern 5 times and wait for 30 seconds.
2. Select "Forgot pattern" and enter your email account username and password.
3. Make sure you use the same account that was used to activate the device and double check the password by logging in to that email account in a browser.
4. If you don't have access to the original email account, you will need to do a hard reset and loose your settings and apps on the devcice. The data on the memory card will not be wiped though.
Note: if you can't remember your email password, you will have to visit the email service support page to get it reset.
also, see here...
http://www.androidtablets.net/forum/android-tablet-usage-tips-tricks/6280-forgot-your-unlock-pattern.html
or here... http://mytabletguru.com/forgot-password-pattern-unlock-of-android-tablet/
Good luck.
3answers
Forgot home screen password for Samsung 12.2 tablet. How do I unlock it?
also, see here...
1helpful
How do I unlock
also, see here...
Cioecud android
Hi I bought a cioecud tablet PC from Tmart but i couldnt use yahoo messenger and skype video calls. Can you show me how to make video calls from those apps. Thanks
I forgot my lock screen password to my xtreme tablet what do i do
If it is running android, you can usually just enter your password 5 times incorrectly and a "Forgot Password?" button should appear. If it's symbian or windows then you probably have to just factory reset the device.
2helpful
Model q8(a-1) forgot password
Locked android. Forgot google account. Need to reset. How to do this and what buttons to use.
Top Generic Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Generic Tablet and eReader Expert? Answer questions, earn points and help others
