Whirlpool RBS275PD Electric Single Oven Logo
A
Anonymous Posted on Jul 06, 2014
Why does my whirlpool gold accubake range display turns off?
Jorgie the appliance guy
Level 3:
Top Expert:
  • Whirlpool Master 5,639 Answers
  • Posted on Jan 03, 2017
Whirlpool Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1522259
Points
32630
If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem.
Or Why does it take the oven so long to bake?
When the food is taking way too long to bake, it's probably a weak bake ignitor. Replacing the ignitor usually fixes this problem, but you probably want to verify that the ignitor is the problem before replacing it.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element
The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreaker panelto avoid an electrical shock hazard.
When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity.
Test theresistanceof the heating element using amulti meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced.
The reason for my free advice is GOD is good!
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Feb 24, 2008
SOURCE: Whirlpool Gold Accubake oven
depress the broil button for 5 seconds it will revert back to Farenheit
Anonymous
  • 116 Answers
  • Posted on Sep 06, 2008
SOURCE: whirlpool gold accubake GJP84802
If you can gain access to the clock you could find the wires that goes to the bake element - if you can measure and confirm the resistance of the element chances you may have also fried the relay of the board - check it out
Regards
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Nov 07, 2008
SOURCE: How do I change my whirlpool oven back to Farenheit instead of celcius...
its in your manual, did not give model number so i looked up anyone. if this does not work you can enter your model number here for a copy of user manual
http://shared.whirlpoolcorp.com/product_literature/search.jsp
To Change:
Press and hold CUSTOM BROIL for 5 seconds. A
tone will sound and “C” will appear on the display. Repeat to
change back to Fahrenheit.
Anonymous
  • 530 Answers
  • Posted on Jun 16, 2009
SOURCE: We tried using the self clean on our Whirlpool
take the trim peices off. take the screws that hold it to the wall out slidee unit out a little to remove the 2 screws from the consol lift the consol up and off. make sure that you have turned the power off inside the unit you will see a tech sheet that will tell you what that error code means. let me know how it goes the tech sheet is usually on the left side.
Anonymous
  • 15935 Answers
  • Posted on Oct 01, 2010
SOURCE: Have Whirlpool Electric Range super capacity 465
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^TF
Have a Whirlpool Gold Accubake Double Oven. After a power outage, the display is dark and ovens are not responding to keypad. Lights work both from doors and keypad. Directions?
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
I have a whirlpool Gold Accubake System When turn the oven on turn up temp, only goes to 260 c what is the f under c how to change to f to make the temp go up to bake if problem with temp explaincf
To change: Press and hold PRECISE CLEAN for 5 seconds. A tone will sound, and "°C" or "°F" will appear on the display. Repeat to change back. To exit, press CANCEL/OFF.
How do i set clock and keep it displayed on a whirlpool gold accubake oven
http://whirlpool.custhelp.com/app/chat/chat_launch will give you a chat line where the Whirlpool expert will chat with you and help you get your problem solved
My Whirlpool Gold Accubake, smooth top displays E1 - F1 (blinking). I am unable to utilize the oven because the push-button/ touchpad does not work however the electric burners work fine. Any clue? Many...
Hello, Thank You for using FixYa. I will be helping you today.This is erc or control failure. You would have to replace the electronic range control sometimes called the clock depending on your model number
Thank You and please rate my answer if it was helpful..
11helpful
Whirlpool accubake rbd245pdb no power to control
Make sure there's power getting to your range, oven or cooktop. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
If all check out ok with all the above, replace the ERC
2answers
We tried using the self clean on our Whirlpool Gold Accubake Duo system range. It locked the oven door and gave code e1 f5. We disconnected the power and turned back on to the same codes. HELP!!!!!!
3helpful
How do you unlock the oven on a freestanding Accubake gas range/oven? Its a whirlpool gold.
Take a wire coathanger and cut the long wire from the middle.
Bend a small "U" shape on one end.
Slide the "U" in from the left side of the oven door near the top center.
Moving the wire back and forth slowwly to grasp the lock latch.
When you feel the latch pull the wire firmly to the left to open the door.
Then have the latch mechanism repaired.
1helpful
2answers
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 • Ovens
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
