Kenwood KDC-MP235 CD Player Logo
A
Anonymous Posted on Jul 06, 2014
How do you the protect code from a Kenwood KDC 108 ?
5 Related Answers
Anonymous
  • Posted on Oct 03, 2008
SOURCE: kenwood_kdc_mp232_cd_player
please i dont remember my 4 digit and i cantnot use my kenwood kdc-mp232 please send me a 4 digit
Anonymous
  • Posted on Feb 28, 2009
SOURCE: protect mode
Press reset button (small circular button need something with a point) to the left of the 1 channel
Anonymous
  • Posted on Feb 12, 2010
SOURCE: how can i deactivate the protect that blinks in my
Disconnecting the terminal will take to much time.. In between the skip button ,and the #1 on your stereo there is a little dot. Barely noticable unless you know what your looking for, take a safety pin or a screw( anything with a little tip) and push it in. This will restart your stereo. (Car Must be on)
Anonymous
  • 6 Answers
  • Posted on Mar 22, 2010
SOURCE: how can i remove protect mode on my kenwood
find the lil hole in front of the face use a paper clip to reset it if it keeps on doing it you got a speaker going bad
Anonymous
  • 40 Answers
  • Posted on Mar 25, 2010
SOURCE: Kenwood kdc-bt742u flashing protect and no sound
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage, or a bare wire touching the body of the car
Kenwood car steroe KDC-108 error 99 code, how to fix?
Try to press the reset button on Kenwood (It returns to factory
settings when the reset button is pressed)
Every time I turn on my stereo (KDC-108) its in "protect" mode. I've tried to reset it multiple times and also un hook the speaker wires. I don't know the security code because i bought the truck used and...
you might try calling kenwood customer service but you will need the serial number off of you deck and its located on the top of the unit ( you will have to pull it out of the dash )
No power after Kenwood KDC-108 Install
check all power wire connections, and fuses on player, and underdash
How do i get the security code for my kenwood kdc 108 car radio?
what if the faceplate doesn't light up but I can get the eject button for cds to work?
2helpful
I am installing kenwood kdc-mp443u. it is flashing protect and i can't remove it. can you help please?
A speaker wire has a short-circuit, crossed, or touches the chassis of the vehicle it activates the protection mode function.
? Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT" code does not disappear, consult your nearest service center.
I have attached a link for you which is for a free Kenwood KDC-MP443U instruction manual download. Nice receiver by the way!
Kenwood KDC MP443U Instruction Manual
3helpful
Kenwood_kdc_mp232_cd_player
3helpful
2answers
Kenwood cd receiver KDC-MP436U
Protect:- The speaker wire has a short circuit, or touches the chassis of the vehicle, then the Protect function is activated. Wire or insulate the cable properly and then press the reset button. If the "Protect" code does not disappear, consult your nearest service centre.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
