General GEM 120 Mixer Logo
p
particia Gustafson Posted on Jul 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a wire diagram for a model 120 Gem mixer-#1010203964? year 2010
Wireing diagram for model-1010203964- Gem 120- made 2010 used mixer has been re-wired wrong? no numbers on circut block? 2010.
Charles Karcher
Level 2:
Sergeant:
  • Expert 213 Answers
  • Posted on Jul 06, 2014
Charles Karcher
Expert
Level 2:
Sergeant:
Answers
213
Questions
Helped
123542
Points
916
Hi Patricia,
Go to this link for the machine manual pdf. On page nine, WIRING DIAGRAM - GEM120A-10.
http://www.fiestafoodservices.com/img/thermalservers/pdf/gem120a.pdf
Fare. Well. My Lady.
Testimonial: "I am very happy with your service-and very fast response. a real Gentelman I am Sure."
Can I Have a wireing diagram for Uniworld m20e year 2012
hi, can i have a wire diagram for a M20E please i changed the contractor but still not working i guess misplace some wire?
thank you
My hobart n50 mixer,when pluged in does nothing at all. why? and what to do?
The N50 is a heavy duty / commercial counter top mixer. It is available in several different versions for different power sources. Make sure yours is the model for use with the power available at your location. The power versions are:
100-120/60/1, 100/50/1, 230/50/1, 220/60/1 and 230/60/1
This lists the information in the following format: voltage/frequency/phase. If used in the US or Canada (and many other parts of the world) you would most likely want the 100-120/60/1 or the 230/60/1 version. All are single phase, so this shouldn't be an issue to worry about. Use of any of the other versions could result in shortened life expectancy of the mixer or immediate, catastrophic failure of the mixer and possibility of burns, shock or electrocution if connection is attempted.
If the mixer matches the power available, check for proper wiring at the source point of connection and in the mixer. You may need an electrician to change the power at the connection point from 100-120/60/1 to 230/60/1 (or vice-versa since BOTH are available in North America). Also check to be sure that fuses or circuit breakers in the electrical panel are intact and on. Do not overlook GFI outlets if using the 100 to 120/60/1 version. Reset any tripped GFI outlet. If still unable to operate, verify that power is present at the connection point. If unable to operate, contact an electrician to check the power and wiring of the mixer.
The mixer data sheet is available here.
1helpful
2answers
I need a wiring diagram for the Hobart H600 which has a multi tap motor on and i would like to change the voltage on the motor to 200volt single phase 120/208 or even 120208 3phase. The wiring diagram is...
You cannot wire a three phase motor for single phase and you cannot wire a single phase motor for three phase. If you have a three phase dual voltage motor your options are 220 or 440 volts. If you have a single phase dual voltage motor your options are 120 or 240 volts. A 208 volt Hobart motor will only function correctly on 208 volts and is not dual voltage.
3answers
Circuit/wiring diagram for KENWOOD CHEF - Model A701A
BRG1 Please can you also email this to me
mal at speciss.co.zw
A - 200 3 speed mixer needs a wiring diaram
how do you know diagram is wrong , you could have wired it wrong the timer kit i belive comes with 3 or 4 different diagrams for that mixer you need to pick the right one
CDM 150 IPOD question
OK all you need is a 1/8 th inch stereo jack that goes out into two RCA cables RED and White (you can get this conector at any radio shack) now plug the red and white wires into the back of your gem sound unit AUX or TAPE..plug in your mp3 through headphone jack into 1/8 in plug....now turn on set switch to AUX OR TAPE DEPENDING on the one you plug into ..now play your mp3...make sure volume is up!
This should fix YA!
4answers
NEED A WIRING DIAGRAM FOR A A200 HOBART MIXER
I had a look on google and came up with a service manual. not sure if this has the wiring diagram but the only other thing i can suggest is to contact te manufacturer direct. Go to http://cgi.ebay.com/HOBART-A200-20-QUART-MIXER-SERVICE-PARTS-MANUAL_W0QQitemZ160203114233QQcmdZViewItem
hope this helps.
Top General Food Mixers Experts
ADMIN Eric
ADMIN Eric
john h
ADMIN Andrew
ADMIN Andrew
Are you a General Food Mixer Expert? Answer questions, earn points and help others
