Question about QPS Q see QT426 Video Surveillance System
System initializing it is stuck on system initializing does not go beyond that
System initialize stuck on printer's panel
plese replace the your printer laser scaner unit
Mar 10, 2014 | Samsung Office Equipment & Supplies
My konica bizhub c550 does not go past the hour glass when powered on, how can I fix this please?
Something maybe mechanically stuck. The printer is expecting something to happen which is failing to happen. Maybe the carrage has to go to one end then back again when you turn on.
Nov 15, 2013 | Konica Minolta Bizhub C550
My player stays on the opal initializing screen
ele nao ta ligando so assim initializing
Jun 26, 2010 | RCA M4204 MP3 Player
Err 4
Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
Jul 02, 2009 | Taylor 5757 Digital Glass Body Fat Scale
Fly installed but won't boot beyond initial screen on my Vista 64
Any way you can run a parallel? Just a suggestion.
Thank you for using Fixya - Please rate the responses to your free questions.
Apr 09, 2009 | Gathering of Developers Fly! for Windows
No CD... iRiver h10 stuck on system initializing
Try Here:
http://iriverinc.com/support/hd/
If that doesn't work check out the forum at:
http://www.misticriver.net/forums/h-10-h-20-series/
Dec 23, 2008 | iRiver H10 MP3 Player
The samsung monitor ssc21web shows system initialize... the three periods blink
ssc21 web does not work, It was a cameras shut down it says LA and AL why
May 15, 2008 | Samsung 4 Channel Dvr
Problem with Administrator Settings
try to open the windows in safemode to open windows in safe mode press F8 when your system start
if you can work in safemode try to restore windows to a pervious date
Apr 30, 2008 | Sony VAIO PCG-V505EC Notebook
QPS Q see QT426 Video Surveillance System Logo
516 people viewed this question
Top QPS Home Security Experts
U-Spy Store DBA Pro...
Are you a QPS Home Security Expert? Answer questions, earn points and help others
