Samsung PL120 Digital Camera Logo
b
berhanu Posted on Jul 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ES90 ZOOM DID NOT OPERAT - Samsung PL120 Digital Camera
Harrie
Level 3:
Top Expert:
  • Samsung Master 6,746 Answers
  • Posted on Jul 06, 2014
 Harrie
Samsung Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1283719
Points
83153
If your camera does not operate as you expect, just switch it off, remove the battery for a few moments and replace the battery. Then switch on again.
If you (accidentally) touched the lens barrel, while using the zoom, the camera can act strange, because it tries to protect the hardware for extra damage.
If switching of and on again, does not solve the problem, you should contact a certified Samsung repair centre.
My camera ES90 will not charge, when i plug it in it seems dead
There can be more than one reason:
The battery can't be charged anymore, because it is defect.
The cable you use is defect
The charger you use is defect
One or more contacts are dirty or oxidised
Carefully check all contacts on the battery, in the camera the battery compartment but also the USB slot, where the charge cable goes in. The contacts should be clean and shiny. No contact should be bent. Cleaning with a dry cloth or cotton swab.
If the cable to charge is defect it is more difficult to detect. Only when you have another apparatus that can be connecter with the same cable, you could check if your cable is still in working order.
The charging source can be defect.
If it is a charger, you plug in a wall socket, check if you can use it to charge something else. If you put it in a PC, also check if that USB port can deliver 5 volt with enough current.
I do have a little gadget, from the beginning of USB and LED lights. An USB plug with a small cord and a LED light on the end of it.
You could use it as a reading light on a laptop. But it showed very helpful to show if a charger or a USB plug on a computer still is delivering 5 Volts.
I hope you find the culprit.
Success
My es90 camera zoom did not operate normally why?
Gears in the lens are worn. Time to replace the camera.
Es90
Start with http://www.samsung.com/au then click "Product Registration" at the top of the page.
The zoom did not operate normally
Zoom al l the way to zero and then manually push Lenz all way in and start from there .see if that works
How long to charge a digital damera
it keeps on saying zoom did not operate normally
Samsung ES90 Digital camera will only take 8 photos then says memory full even when fully charged
The Samsung ES90 only has about 37MB of built-in memory. The state of the battery has no effect on this. If you want to take more photos then you can either make them smaller, or better yet, add a memory card.
Manual
Canons website should have the manual available for download.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
