I would like my gmail placed into my microsoft outlook contact area
Here is a link to the google app to sync with Microsoft outlook.
https://tools.google.com/dlpage/gappssync
OK
try these steps:
NOTE You can delete this file after your contacts are imported into Outlook.
Thanks to:
Microsoft at:
http://office.microsoft.com/en-us/outlook-help/transfer-contacts-between-outlook-and-google-gmail-HA010222048.aspx
SOURCE: microsoft outlook
No, because Microsoft outlook only works with hotmail, yahoo and AOL Mail.
PLEASE RATE MY ANSWER AS SOON AS POSSIBLE!
SOURCE: how to manage two different email ids in microsoft outlook?
Considerations Before Accessing Multiple Accounts
Before using Outlook to access more than one email account there are some caveats to this type of access.
• All email will be delivered to one inbox unless another Outlook Data File is created for the account and a rule created to move the message to the data file. If storing all in email in one data file is acceptable then a rule can be created to move the email to a folder to keep accounts separate.
• When creating or replying to an email you need to select which account the email should be sent from. This is accomplished by selecting Accounts in the mail compose windows and selecting the account to use.
Steps for Setting Up an Additional Email Account:
1. Tools
2. Email Accounts
3. Select Add a new email account click Next
4. Select POP3
5. Fill in Your Name
6. Fill in Email address for account
7. Enter User Name for account
8. Enter Password for account - check Remember password if you don’t want to login each time you send and receive email.
9. Enter Incoming Mail Server (POP3) – Information provided by ISP
10. Enter Outgoing Mail Service (SMTP) – Information provided by ISP
If this is all the information the ISP requires then click Test Account Settings to determine if everything is setup correctly. If additional information is required follow the steps below. If Outlook can perform a test send/receive with no errors then you are finished! Click Next and then Finished.
If the test fails, check your settings to make sure everything is entered correctly. Pay close attention to the username and password fields as this is usually where the problem occurs.
Additional Information
If the ISP requires outgoing authentication follow these steps:
1. Click on More Settings
2. Click on Outgoing Server tab
3. Check the box next to My outgoing server (SMTP) requires authentication
4. Make sure the Use same settings as my incoming settings is selected
5. If this is all of the required information click OK and then Test Account Settings
If the ISP requires that Server Port number needs to be changed:
2. Click Advanced Tab
3. Change the Incoming or Outgoing Port Number to the number provided by ISP
4. Click on OK and then Test Account Settings
SOURCE: Microsoft outlook on my verizon HTC SMT5800
Unless you are trying to sync with another Microsoft Exchange Server (say at your new Job) or you are running an Exchnage server at home on a dedicated server.. you will not be able to set your phone up with exchange.
One Suggestion I may have would be to setup outlook on your phone to connect to your email via Imap4 or POP3.
You might want to remove the activesync partnership to your old company if you havent done so allready to help get rid of the exchnage sync error's.
Hope this helps.
SOURCE: Cannot start Microsoft Office Outlook. Cannot Open
It looks as if your outlook is set to look for a Microsoft Exchange Server. If this is the case check the settings are correct.
If you are not using Exchange then you will need to change the server type to your POP3 mail server.
If you have problems post a reply.
