Question about Cobra 29 LTD CB Radio
How do I turn down my power on my cobra 29
How do I turn down the power
    Novelist:
    Scholar:
  • 114 Answers
This is not a user-accessible function. You would need to take the radio to a qualified repair person, i.e., a CB repair shop
If the radio power output is 4-watts or less, as measured by an accurate wattmeter connected to a dummy load, then there is no need (from a legal perspective) for reducing it.
Posted on Aug 07, 2014
6ya staff
SOURCE:
One Wire
Dean Pitts
  • 126 Answers
SOURCE: echo on cobra 29
When you purchase an echo board, the instructions come with them.
If you need any help, don't hesitate to email me at rollincbmods@yahoo.com
Dean Pitts
Rollin CBs
Posted on Aug 31, 2008
wyoed1
Ed Meshechek
  • 211 Answers
SOURCE: cobra 29 ltd modulation problen
You need to check the modulation on a modulation meter. Just because the meter doesn't peg, doesn't mean the modulation isn't working. Usally a meter pegging, means the swr's are too high or the meter is misadjusted. If in fact the modulation is low, their is a pot inside the radio (VR4) that will add gain to the modulation circuit. This setting is legally supose to be set by a qualified technician.
Good Luck
Ed Meshechek ( Radio Man )
NC Electronics
PO Box 1696
414 6th St.
Mills, Wyoming
82644
307-266-4675
wyoed1@aol.com
Posted on Dec 03, 2008
Don Reiman
  • 773 Answers
SOURCE: cobra 29 ltd classic antenna calibration ??
Wow. That's not at all a solution to what this guy is asking. And why all the caps??
The one point jm77437 has that is correct is that you do not set the radio, you set the antenna. The rest is blah blah.
Here is how you tune your antenna for you radio. First off it depends on what kind of antenna you have. most fiberglass antennas have a tunable tip to adjust the height of the antenna. Metal whips either have a collar at the base that the whip will either slide up or down in to adjust the height. The other type of metal whip's you have to physically clip to shorten the antenna, you must be careful with this type because once its clipped, that's it. You cannot add what you cut off.
I am going to give this example using a metal whip with an adjustable collar.
First after your radio is hooked up in the vehicle, drive to an open lot. Buildings and other structures can cause extra reflection. turn to channel 1. Flip the meter to CAL. Key the mic without talking. Now turn the CAL knob up until the needle reaches the little upside down triangle all the way to the right marked CAL. Now you have just celebrated your radio for your setup to measure you SWR. Now while still holding the key, flip the meter switch to SWR. The needle will move, and where it stops is your SWR reading. The lower the better. Anything under 1.5 is considered really good. But still, the lower the better.
Make note of what your SWR was on ch 1.
Now flip to channel 40. Repeat the SWR process. You must recalabrate each time you take a reading.
Now like jm77437 said. If your SWR reading is higher on 40 then 1, then your antenna is too long, and you must make it shorter. Loosen the collar and lower the antenna in the collar 1/4 inch at a time. check the swr each time you adjust the antenna.
If your SWR reading is higher on channel 1, then your antenna is too short. You must make your antenna longer. Do this by loossening the collar and pulling the antenna upward in the collar 1/4 inch at a time, again checking the swr each time you adjust the antenna.
What you want to achieve is having the same SWR reading on channel 1 and 40. then you have the best match you are going to get with that antenna.
If your swr is under 1.5 on all channels, you don't need to fuss unless you are a perfectionist. then by all means go ahead.
If your reading is higher then 3, or your ant light comes on, something is really wrong. Make sure your antenna is connected all the way, and the coax is not damaged.
Its important to have an appropriate SWR because if you do not, you are reflecting too much signal back into the radio, and eventually you will burn out your final transistor, and your radio will be toast.
Some tips: make sure you check the swr with the doors and windows shut. Make sure you are in an open lot. Remember to calabrate ecah time you take a reading. If you have had your radio peaked by a radio shop, and they have lowered your dead key, or have done a swing modification, then the meter in your radio will not work when taking an SWR reading and you will have to use an external meter.
Posted on Apr 24, 2009
Don Reiman
  • 773 Answers
You should not calibrate the antenna before you install it on the car!! the antenna needs to be calibrated on the vehicle that it is going to be on. Type of vehicle, different mounts, and many other variables can change the amount of reflection you will get.
j0hn9999 did a much better job but left some info out.
Take your SWR readings on channel 1, then on channel 40.... NOW, if your SWR is higher on ch 40 then ch 1, then your antenna is too long and it needs to be shortened. Refer to the antenna instructions on how to shorten the antenna.
If your SWR is higher on ch 1 then on ch 40 then your antenna is too short. You must lengthen the antenna. Again refer to your antenna instructions on how to lengthen your antenna.
You must calibrate each time you take a reading.
Make sure your doors and windows are shut when taking a reading
Make sure you are in an open lot when taking a reading as buildings, trees and other structures can cause reflection and give you an inaccurate reading.
If you adjust the length of your antenna on another vehicle and then put it on yours, the SWR will be off. It will need to be tuned again.
An external meter is better then the one in the radio, but will need to be hooked up in the vehicle you have the antenna on.
If you are not running any kind of power, or do not have a swing kit installed, and the radio is stock, the meter in the radio is more then enough to get a correct SWR reading.
Anonymous
  • 89 Answers
SOURCE: Receives but does not transmit. It is a Cobra 29
There are a few different things that can cause this problem. 1: If it is a power microphone (a microphone that requires a battery). Try replacing the battery. 2: Broken wires that go from the microphone to the plug that plugs into the radio.You can try gently taking the plug apart and inspecting the wires. If only one has come loose, you can re solder it to the pin it came from. If more than one has come loose, find a wiring schematic for the radio that tells which wire goes to which pin and re solder appropriately. 3:Have the SWR's checked on the antenna. If the SWR's are to high and the radio has been being used in this fashion, it could have burned up the transmit finals in the radio. If this is the case, you will need to take it to a reputable radio repair facility to have fixed.
Posted on Nov 30, 2009
Lamp timer reset for toshiba tlpx100
To reset the lamp counter:
  1. Turn power off and unplug the power cord
  2. Simultaneously hold down these three buttons: "ON/STANDBY", "RETURN", "DOWN" (the arrow down symbol)
  3. Plug in the power cord while still holding down the buttons.
    The Projector will emit a series of beeps.
  4. Turn on power using "ON/STANDBY" button and check that "0H" appears on the lamp time in the status display.
  5. Turn off projector using "ON/STANDBY" button
  6. Unplug power cord.
I hope this helps.
Sep 25, 2013 | Toshiba TLPX100 Projector
Tip
How To Reset Your Samsung Vibrant
<span style="font-weight: bold;">Soft Reset</span><br /> <ol> <li>Turn the power off.</li> <li>Remove and reinsert the battery.</li> <li>Turn the power on.<br /></li></ol><span style="font-weight: bold;">Hard Reset</span><br />A hard reset will reset all of the settings and data. The phone will return to factory default settings without affecting the data on the SD card.<br /> <ol> <li>Turn the power off.</li> <li>Press and hold down the <b>Volume Down, Volume Up</b> and <b>Power</b> buttons simultaneously.</li> <li>When the Samsung Vibrant logo appears on the screen, release the buttons.</li> <li>Press the <b>Volume Down</b> button to select <b>Delete all data</b>.</li> <li>Press <b>Power</b>.</li></ol><br />
on Feb 15, 2011 | Samsung Vibrant
How to turn down the deadkey on galaxy 48t to 4 watts the rf power knob will take it to 25 watts only
You can turn down VR18 which is your low power but as you turn it down your high power may go down also. If that's the case then you have to adjust L40,L42,L43,and L44 . If you don't have a scope don't even try it . 10 watts low may be the lowest you'll get. You can also try changing a few Elec. caps. to bring it down more and thats where the scope will really be handy.
Aug 15, 2013 | Radio Communications
Looking for a solution to an error 6502 on canon printer mp510
turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be releasedbefore doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Jul 25, 2011 | Canon Office Equipment & Supplies
I have a toshiba estudio 200l wuth perform preventive maintenance on display. How do I clear off of screen?
turn off power
hold down 0 & 8 keys
turn power on with keys still held down till beep is heard
enter 252 then press start key
enter 0
press enter icon on display
power off & on
should clear service message
Feb 15, 2010 | Toshiba Office Equipment & Supplies
Monitor turns itself off
hi, you must have enabled power saving options. Thats why your monitor shut down. you can disable, just do the same:
1.Right click on desktop
2.Select properties.
3.Select "ScreenSaver".
4.Select "Power" under Monitor power option.
5.There select "never" from Turn off monitor (drop down menu).
Now your monitor will not turn off automatically.
Sep 19, 2009 | Dell Inspiron 531s Desktop Computer
No front speaker sound
Microprocessor reset.
For US and Canada:
  1. Unplug the power cord from the wall outlet, then plug it back in while holding down the POWER key.
For other countries:
  1. With the power cord plugged in, turn the POWER key OFF. Then, while holding down th ON/STANBY key press POWER.
Jan 12, 2008 | Kenwood VR-209 Receiver
Panel lock on dra 397
Speaker B and Mode buttons held down simultaneously while engaging master power, unlocked my DRA-397. Thanks!!!!
Dec 02, 2007 | Denon DRA-397
Cobra 29 LTD CB Radio Logo
319 people viewed this question
Top Cobra Radio Communications Experts
Chris
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
