My tablet refuses to fully charge even after two days, and when it does charge there is only about twenty-three percent and it dies very quickly.
Your tablet may need its battery calibrating. To do this run your tablet until it turns itself off, this will ensure that there is no charge left in the battery. Then leave it on charge until the battery is full. Normal battery use on modern devices like tablets and phones should be between 25-75%, with a calibration once every 3-6 months to ensure a good battery lifespan. If this solution does not work you may need to replace the battery.
Testimonial: "Every time it does charge though, I will turn it on and leave it till it dies completely, then I will charge it fully, but the battery drains faster every time I do calibrate it. So does that mean I need to return it and get the battery replaced?"
