Lower tray won't transport
SOURCE: brother mfc 8840d, need a ADF left hinge - where can get it?
you can get it from us.
thanks adi
SOURCE: Brother MFC 8460n paper pickup
Hi tkennedy0720,
Please follow these steps to assure you have made sure there is no jam.
1. Press the cover release lever to open the front cover.
2. Take out the drum unit and toner cartridge assembly.
3. Open the back cover.
4. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
5. Using both hands, gently pull the jammed paper out of the fuser unit.
6. Close the back cover.
7. Put the drum unit and toner cartridge assembly back in the machine.
8. Close the front cover.
9. Press the cover release lever to open the front cover.
10. Take out the drum unit and toner cartridge assembly.
11. Hold down the lock lever on the right and take the toner cartridge out of the drum unit. Take out the jammed paper if there is any inside the drum unit.
12. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
13. Put the drum unit and toner cartridge assembly back in the machine.
14. Close the front cover. Pull the paper tray completely out of the machine. Use both hands to slowly pull out the jammed paper.
15. Press the cover release lever to open the front cover.
16. Slowly take out the drum unit and toner cartridge assembly. The jammed paper may be pulled out with the toner cartridge and drum unit assembly, or this may release the paper so you can pull it out of the paper tray opening.
17. Put the drum unit and toner cartridge assembly back in the machine.
18. Close the front cover.
20. Put the paper tray firmly back in the machine.
21. Take out any paper from the ADF (automatic document feeder) that is not jammed. Open the ADF cover. Carefully pull out the jammed document to the left. Check for and remove any small pieces of paper stuck in the machine. A small piece of paper stuck in ADF will cause a document jam.
22. Close the ADF cover. Press Stop/Exit. If the Document is jammed under the document cover. Take out any paper from the ADF that is not jammed. Lift the document cover. Pull out any jammed documents to the right. Again, carefully check for and remove any small pieces of paper.
23. Close the document cover. Press Stop/Exit. If the Document is jammed at the output tray. Take out any paper from the ADF that is not jammed. Pull the jammed document out to the right.
24. Press Stop/Exit. If the Document is jammed in the duplex slot (only for machines which support Duplex printing). Take out any paper from the ADF that is not jammed. Pull the jammed document out to the right.
25. Press Stop/Exit. Make a Copy to test. Before placing your document(s) in the ADF verify the error message "Document Jam" in no longer displayed on the LCD. If the error message continues to appear on the LCD, please contact Brother Customer Service from "Contact Us". Verify the ADF document support (located on the top of the ADF) is pulled out. Verify the document(s) are between 5.8 to 8.5 in. wide and 5.8 to 14in. long. Make sure the documents are inserted face up in the ADF, top edge first. The ADF can hold up to 50 pages and feeds each sheet individually. Use standard 20 lb (80 g/m²) paper and always fan the pages before putting them in the ADF.
Note:
DO NOT use paper that is curled, wrinkled, folded, ripped, stapled, paper-clipped, pasted or taped. DO NOT use cardboard, newspaper or fabric. Make sure documents written with ink are completely dry. Adjust the paper guides to fit the width of your documents. This ensures the document(s) will feed straight, preventing jams. Make a copy listed below:
For MFC users :
Press Start.
For DCP users :
Press Copy located below the LCD and then press Start.
Hope it helps.
Thank you for using FixYa.
SOURCE: Brother MFC-8840D ghost image
Our Company has this problem after replacing the toner with a new one. Through trouble shooting with Brother I eventually realized that the warranty sticker which states 'do not remove' (it covers a plug used to fill the ink) had been removed and re-stuck on in broken pieces. This means our warranty for the toner is no longer valid as the toner was tampered with and refilled with different ink. Further investigation: I opened all the new toners we had ordered from PITNEY BOWES to find every single one had the sticker removed meaning they had refilled the toner cartridges them selves and re-sold it to us at FULL price with no warranty. Don't order Brother ink from any other supplier than staples or brother, and always check for the warranty sticker when you go to use it. The other inks we ordered from Pitney Bowes destroyed our drum in the colour printer because it explode out of the ends.
